- Mute
- Permalink
- Report
I rotated the UCS and now when I try to edit Mtext it looks like this, see screenshot. Thanks
Link copied
Set your UCSFOLLOW to 0
UCSFOLLOW is set to 0.
I think it has something to do with annotative text, when i change the scale back and forth it seems to work fine.
Here ya go
Thanks for the DWG file from MAP3D. Is that your actual program?
Not seeing any autorotation when I edit your georeferenced MTEXT sample in your UCS rotated file. How else can I replicate your issue in this sample? can you replicate the issue in this sample?
Your screenshot angle appears to match your UCS rotation for sure, 288.16, just not here in plain AutoCAD (software topic of this forum)
TIA
I found this thread but it doesn't seem to help
I just found the solution on another thread......
Check and make sure the linetype fpr the layer the text is on is not a custom linetype. Text should use continuous as the line type.
I was having the same issue and it was fixed when I switched the linetype from "water main" to continuous.
