Editing Regions
Editing Regions
Message 1 of 11
Editing Regions
I need to edit a regions without having to explode it back to lines,
Exploding it back to a closed polyline would be okay or even better being able to edit the region itself.
Replies (10)
Message 2 of 11
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Sorry, not possible.
(In most cases) You can use command _BPOLY to generate a closed polyline from the region (or more polylines if the region has islands).
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 11
Thanks, i thought that was the likely answer bpoly may help i'll give it a try
Message 4 of 11
SEANT61
AutoCAD's direct Region editing via Selection-Filter-Edge has continually gotten more competent over the releases. Moving edges, both internal and external, has been possible for a while. 2017 now looks to be able to Scale and Rotate features as well.
May your cursor always snap to the location intended.
Message 5 of 11
Alfred.NESWADBA
Look into that drawing, on the left side the original objects, from that I created a region using _BPOLY and moved it to the right.
Now try to modify any segment of that region 😉
On my system (AutoCAD 2017 SP1) when you select an edge the complete figure/region moves to the right.
Combined with the limited handling (no grips, not all commands like stretch) I would say for me that's not editing like CAD should work. But mentioning that edges can be selected and modified was very good (as I forgot that option to write in my post).
- alfred -
Alfred NESWADBA
Message 6 of 11
SEANT61
AutoCAD's ability to manipulate spline geometry has gotten better over the years as well.  But, if there's anything that will throw a curve to an AutoCAD operation, it will probably be spline based.
Message 7 of 11
THANK YOU BUT I CAN'T SEEM TO GET IT TO WORK
COULD YOU EXPLAIN FROM THE START AGAIN?
Glen Tregenza
Draftsman (QLD)
E glen@europrecast.com
P 07 3278 2725
451 Sherwood Rd, Sherwood QLD 4075
WWW.EUROPRECAST.COM
Message 8 of 11
SEANT61
See the attached screencast.
Message 9 of 11
GrantsPirate
You can subtract and union regions, that is about it for editing.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 10 of 11
Thank you,
That has solved my problem, the trick was 3d modelling workspace.
Message 11 of 11
thanks!!! able modyfing vertex as well???
