Editing Properties Panel Acad 2017
Felix_I
Felix_I
I've just switched to 2017 and I was unable to import my 2012 settings properly. I lost the Line weight and Line type in the Properties panel. See attached picture 1.
I would like to have just like this guy here, see picture 2.
Can someone please tell me how to I get that panel back and how do I add Match Property tab?
Thank you.
Felix
imadHabash
>> I've just switched to 2017 and I was unable to import my 2012 settings properly. <<
it's NOT recommended if you trying to import AutoCAD 2012 Settings to AutoCAD 2017.
>> Can someone please tell me how to I get that panel back and how do I add Match Property tab? <<
i suggest to reset your AutoCAD to default settings . >> Click <<
also it's important to install the last service packs and update. >> Click <<
Imad Habash
Alfred.NESWADBA
maybe it is already back by just resetting the menu, not all the settings.
Open command _CUI, right-click the top most item and select one and use the reset option
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Felix_I
Yes, I was missing an update, a service pack.
Updated and all looks good, see pic attached, thank you for the help, kudos 🙂
Felix
