Editing Dimensions with Double Click
Message 1 of 15
I am working in AutoCAD 2016 and I am trying to change the setting so that when I double click a dimension, the text editor appears and I can change the text.  I have read multiple strings of forums about going into the CUI panel and looking under the Double Click options and then under Dimension - however, in my CUI panel, there is NOTHING that says "Dimension" listed anywhere - not under Double Click or anywhere so how can I update the setting if I do not even see this option.  I looked in my AutoCAD 2015 version and it is listed but not in 2016.
Help me!
-R
Replies (14)
Message 2 of 15
rkmcswain
If you right-click on "Double Click Actions", you should be able to add "Dimension".
Then add the Object Name = DIMENSION
Then you should be able to add TEXTEDIT as the command to execute.
Message 3 of 15
leothebuilder
You should not edit dimension text. You should adjust the geometry to which the dimension applies.
The command to edit dimension text is TEXTEDIT.
I would add somenting to your PGP file as a shortcut to this command.
I have mine as DD
Message 4 of 15
pendean
Community Legend
Community Legend
This works by default in R2016 here: are you running an add-on? Custom menu file?
Migrate?
Sounds like you loaded a primary menu file from somewhere else too, I see the entry in the CUI here
Message 5 of 15
rkmcswain
I don't think this is an unreasonable request.
We have dimstyles that report the distance of the dimension, but the prefix and suffix are different each time. We couldn't create a dimstyle for each situation, even if we wanted to.
So edit the distance? Not generally.
But editing the entire dimension string? Yes, all the time.
Message 6 of 15
This is the tutorials I found but I cannot find the "Dimension" type listed under DOuble Click actions. I just need to be able to change the text of a dimension from either a number or to "EQ" if necessary.
Message 7 of 15
I tried to create a new Double Click Action with Dimension title but this still does not resolve the issues.
How would I migrate the CUI settings from Autocad 2015. I installed 2015 then installed 2016 and it does not show any migrated settings.
Message 8 of 15
leothebuilder
In the CUI, rightclick "Double Click Actions", select "New Doubleclick Action" and add "Dimensions".
Now from the lower pane where all the commands are listed, scroll down to the TEXTEDIT command and drag and drop onto the new "Dimensions" you just created.
Message 9 of 15
Did exactly that and it still does not allow me to edit the text on my dimension line.
Message 10 of 15
Got it! The Text edit was listed with a comma so it was not showing up when I typed it in!
Thanks for all your help!
Message 11 of 15
rkmcswain
At the AutoCAD command line, type in DBLCLKEDIT and press enter.
What is it set to?
Message 12 of 15
It was set to ON
Message 13 of 15
I am not able to find TEXTEDIT under the command list in CUI.  So I tried creating my own TEXTEDIT command, with the macro ^C^C_TEXTEDIT (Used from another computer).  This did not work.. I am running DIEMAKER, an add-on to Autocad, which I believe is the initial culprit, but not sure why the command doesn't even show up.
Below is the screen from the autoCAD CUI that works, so I mirrored this on the other computer and still no luck.  The new computer creates a new Element ID (Not ID_TEDIT).  I did a command search in the CUI and TEXTEDIT comes up for other commands.
I also backed out of CUI and typed in "TEXTEDIT" in the command line, and the command works from the command line for editing text.
To make my issue clear:
     -Want to be able to double-click Dimension text to edit it.
     -Tried Adding "TEXTEDIT" command to "Double Click Actions", but could not find "TEXTEDIT" in the Command List
     -Tried Creating a new "TEXTEDIT" command using "^C^C_TEXTEDIT" for the Macro
     -"Properties Menu" still comes up when double clicking dimensional text
Thank you in advance,
JG
Message 14 of 15
carminatithekid1
I have the same issue of it not working. What is going on? I have tried everything listed on this thread. Nothing is working.
Randy Carminati
Message 15 of 15
After doing all of the above, you may need to enter "dimension" to the blank object name under advanced on the right panel.
