Editing AutoCAD Field Expression or Diesel expression editing - Insert file name
Message 1 of 16
How would you enter a file name but remove the last four characters?
For example, after typing field in AutoCAD, you can grab the field expression string:
%<\AcVar Filename \f "%tc1%fn2">%
Which will add the file name.
How can you do this but remove the last four characters:
WL-A-XYZ_R1A would become WL-A-XYZ
So I dont have the revision R1A displayed
Replies (15)
Message 2 of 16
rkmcswain
You can use this DIESEL expression.
$(substr,$(getvar,dwgname),1,$(-,$(strlen,$(getvar,dwgname)) ,8))
Which means the field code string will be:
%<\AcDiesel $(substr,$(getvar,dwgname),1,$(-,$(strlen,$(getvar,dwgname)) ,8))>%
Message 3 of 16
You can try this:
$(substr,$(getvar,"dwgname"),1,8)
Message 4 of 16
rkmcswain
@Anonymous  wrote:
You can try this:
That only works if the portion of the file name you want to retain is eight characters long.
See above, where that DIESEL statement reads the entire file name, no matter what the length, and removes the last eight characters, which is the four character suffix and the four characters ".DWG"
Message 5 of 16
@rkmcswain  Exactly!!  My expression goes from character 1 to 8, since its name is 12 it will remove the last 4.
His expression got much better Heart
Message 6 of 16
rkmcswain
That makes little sense. Why hardcode something to only work in one particular case, when it can be written so that it works in multiple scenarios?
Message 7 of 16
True, but how do you add that extra feature in the code?
Message 8 of 16
¿Cuál sería la cadena para eliminar los caracteres "x" delante y "x" detrás. ¿Sin tener en cuenta la longitud del nombre de archivo? Gracias
Message 9 of 16
neabailey
@rkmcswain This has been super helpful. Is there a way to remove the first 4 characters instead of the last 4? For example making file name WSS-titleblock-01.dwg look like titleblock-01.dwg.
~nic
Message 10 of 16
dvicarioXT
That should be easier, try this:
$(substr,$(getvar,dwgname),5)
Where 5 is the position of the first character you pick. You can also exclude a certain amount of characters from the start AND the end, but it's a bit more complex (I'm not an expert, maybe there's a better way to do that):
$(substr,$(getvar,dwgname),5,$(-,$(strlen,$(getvar,dwgname)),8))
You take away 4 from the beginning (so you start with the 5th character) and 4 (8-4=4) from the end.
I hope that helps
Message 11 of 16
cadffm
deleted  ~superfluous~
Sebastian
Message 12 of 16
ryan_gajelomo
Community Visitor
Community Visitor
@rkmcswain can you help me with this? i am trying to get only the "ceiling light feature detail" only. but the last 11 characters are not removed.
this is the filename:
MDGI_MDG_L1_A0_X1.1.406_CEILING LIGHT FEATURE DETAIL_250801.dwg
and i used this diesel expression:
$(substr,$(getvar,dwgname),25,$(-,$(strlen,$(getvar,dwgname)) ,11))
i am trying to get only the "ceiling light feature detail". but the last 11 characters are not removed.
did i failed at somepoint? any help is much appreciated. thank you!
Message 13 of 16
cadffm
and the part starts always with character 25 and ends 11 befor end ??
Substr , "string" , start character nr, length
String: dwgname
Start: 25
Length: full length - 24 - 11
Your "length" part should be:
$(-,$(strlen,$(getvar,dwgname)),35)
Untested
Sebastian
Message 14 of 16
ryan_gajelomo
Community Visitor
Community Visitor
hi, thanks for your reply. to answer your question, yes, it always begins with 25th character.
after searching for some time, i somewhat found a solution to my query. i forgot to save the link where i found it, but i think it's from cadtutor.
Here's what he/she did:
$(substr,$(substr,$(getvar,"dwgname"),1,$(-,$(strlen,$(getvar,"dwgname")),11)),25)
wherein it gets the whole string length that begins with the 25th character and subtract 11 last characters.
from filename: MDGI_MDG_L1_A0_X1.1.406_CEILING LIGHT FEATURE DETAIL_250801.dwg
result: ryan_gajelomo_1-1754035314001.png
it also works for my other files as well:
from filename: MDGI_MDG_L1_A0_X1.1.101_PARTITION WALL FINISH PLAN_250731
result: ryan_gajelomo_2-1754035466069.png
as of the moment, that query of mine is kinda solved.
what i'm having right now is this:
some of the filenames has (example: X1.1.301a).
now, i'm wondering how am i going to add-in the "a" without ruining the result.
please help. many thanks!
Message 15 of 16
cadffm
>"as of the moment, that query of mine is kinda solved."
Glad to help
My DIESEL line would be: $(substr,$(getvar,dwgname),25,$(-,$(strlen,$(getvar,dwgname)),35))
>>"what i'm having right now is this: "
So, A sample filename could be: MDGI_MDG_L1_A0_X1.1.406aCEILING LIGHT FEATURE DETAIL_250801.dwg
Thats unusual, but otherwise your "always from 25" statement is wrong.
Let's see:
substr of DWGNAME
start with char 16
length: IF char 24 is "_", then length is 8, else length is 9
Take a look to the DIESEL catalog and IF function [F1]
$(substr,$(getvar,dwgname),16,$(if,$(eq,_,$(substr,$(getvar,dwgname),24,1)),8,9))
Sebastian
Message 16 of 16
simone_tiezza
Community Visitor
Community Visitor
is there a way to set a character as a "break" in my filename? For example my filename is Test01_02x.dwg and from the expression I would like to get only 02x, so "_" is my break character. My file names have different length but the same syntax (XXXX_YYY)
Thanks a lot
