EDIT BLOCK WITHIN ANOTHER BLOCK IN PLACE
If I have a block within other block (for example a toilet seat which is a block within a flat plan that are also a block) and I want to edit the toilet seat . In the beginning I opened the flat block by (edit in place) which is working fine but when I tried to open the toilet seat by (open in place) the AutoCAD is not allowing this providing this massage ** Command not allowed, (block name for flat) already checked out for editing ** And I had to open the block editor to edit toilet seat block. Is there any solution to edit block within other block in place ?. The reason behind this cuz sometimes I need to look to full layout when editing smaller portion to see how will affect other areas of the layout .. I'm using AutoCAD 2014
Dear Mr.bakooori
Please find the attached screen shot.
Hope this could help you out.
Regards
DMC
Thanks Dear you helped me a lot .. it was so obvious .. couldn't see this cuz I have more than 200 blocks within blocks in my layout .. Thanks again Sir
