Edit Alias for Command Within A Command
Message 1 of 12
Ok so when I work, I use the NEAREST command within object snap a lot, but I prefer that it is not selected all the time when object snap is on.
So when I am using a command already like drawing a polyline or moving the endpoint of a line - within that command i use the alias NEAR.
Does anyone know if I can change the command for this alias command within a command? I'd just like to change it to N.
Replies (11)
Message 2 of 12
Patchy
Not within acad.pgp but it can be assigned to a F function key (e.g. F2, F3.... ) in the CUI
or it can be done with autolisp, and when running the command, use a ' mark.
Message 3 of 12
Kent1Cooper
Just so you know, the first three letters are enough as abbreviations for Osnap modes -- you can type just NEA and get that mode.
But you can also define a "command" for it that can be used transparently.  Minimally tested:
(defun C:N () (command "_nearest"))
To use it in a drawing or editing command, you need to type the name with the asterisk prefix that @Patchy mentioned:  'N.  One keystroke shorter than NEA....
And NEArest could be put in a Tool Palette button, and probably some other menu-pick options.
Kent Cooper, AIA
Message 4 of 12
Patchy
Thank you for explaining it in detail, I know it works like that but if I write it, it confuses people (English is my 2nd language)
Message 5 of 12
Sofia.Xanthopoulou
Hi @Anonymous,
please take a look at this discussion - post no 14. Seems like it could work but should be a lot of work to rearrange all other snaps in order to make NEA working with only a <N>.
Regards
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Message 6 of 12
Patchy
No #14 Smiley Very Happy
Message 7 of 12
Sofia.Xanthopoulou
Oh, come on ... as if you never forget anything Smiley Happy
Well, at least I amused you Smiley Wink
Thanks for the catch Patchy - link is inserted.
Regards
Message 8 of 12
ВeekeeCZ
From my experience (and my settings) are F* keys the best option.
I have F1 for nearest and F2 for perpendicular.
Message 9 of 12
Thanks all. I was able to assign it to F2 which seemed the easiest (and learned about the CUI). Ctrl + right click + "N" doesnt seem to save much effort from typing "NEA"
Message 10 of 12
scot-65
Please unassign the [F2] key. It is used to flip the TEXTSCREEN.
Our setup:
F1 - CEN
F2 - Default behavior (TEXTSCREEN)
F3 - ENDP (notice the 4th character?)
F4 - MID
F5 - PER
F6 - NEA
F7 - NODE
F8 - Default behavior (ORTHOMODE)
F9 - INT
F10 - NONE
F11 - QUAD
F12 - TAN
To access the original key assignment press and
hold the [Shift] key, then press desired F# key.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 11 of 12
bdesign71
Hi, Great idea, can you supply a sample lisp code on how to redefine the f keys. I did it years ago but things change. Thanks and Great skill
Message 12 of 12
Patchy
CUI command, and this is my F9 for snapping to Endpoint.
