Hi everyone,
Great idea this answer day if it works for me.
I have a query for which i partly have the answer, I have several points which are plotted as single lines using the data from a spreadsheet. I would now like to add some text after each line has been drawn so i can identify whichline relates to each data point in the spreadsheet.
An example of the line command i am using is below.
Line 486057.71,512851.35 484919.71,513136.58
Line 486285.39,512547.16 486057.93,512850.95
I would like to incorporate the text command after the line has been drawn which will take the number from the spreadsheet for the corresponding line and place the label text alongside the line before going to draw the next line.
Can anyone help here?
Thanks in advance
Colin from the UK
