Drawing size is only 750KB but autoCad freeze after every command
1629853
1629853
Morning,
The drawing size is small, apprently it was convert from earlier version of AutoCAD. I am using AutoCAD 2015 now and after every simple command, AutoCAD would freeze. I had done audit and purge but the problem remain. Is there a step I'm missing?
Thanks in advance.
Al
Martin_Langolf
Autodesk Support
Autodesk Support
Hi Al,
Please test >>this<< solution for deeper cleaning of the file.
Should this not help, please upload a copy of the DWG so we can analyse it.
Please let us know if this helps.
Martin Langolf
Bernd.Gerstenberger
Autodesk Support
Autodesk Support
so AutoCAD freezes only for this drawing? Not for others? Then try following:
  • Purge in the command line with command "-PURGE" with the options ALL and REGAPP
  • Use command AUDIT and fix the errors
  • Use command WBLOCK and save it to a new drawing
Please, let me know if I could help you?
Best regards
Bernd
Bernd G.
Senior Product Support Specialist
