Easy way to draw a Circular WIPEOUT
skosgoda7
Observer Observer
skosgoda7
Observer
Observer
We have a problem when we need to draw a circular wipeout. There is no option to draw a circular wipeout. Here is the easiest way which I found.
Step 1
Draw a circle on the area in which you need to hide
Step 2
go to the POLYGON command, type 48 (or more than 48) to the number of sides, and draw a polygon using the circle.
(It will be almost a Circle)
Step 3
go to the WIPEOUT command, and select the option POLYLINE, then select the polygon which you created.
That's IT !!!
imadHabash
Hi and Welcome to AutoCAD Forum,
We appreciate your kind idea .
Imad Habash
imadHabash
Also .. you can by this two command program ( cwipe / c2wipe ) will be enabled to create circular wipeouts in the drawing. >> Click <<
All the best ..
Imad Habash
