easiest way to hollow 3d solids
czaborowski
Observer Observer
czaborowski
Observer
Observer
I'm looking for the easy way to manipulate a 3d solid to a skeletal form.
For instance, if I wanted a 3d shape to be hollowed out and see-through, only connected at its angles. Structural framing only.
AVCPlugins
If I understand you correctly, then to see through the solid you just need to switch the visual style to XRay. Or use the regular 2D or 3D wireframe style. Use _VisualStyle command or the on-screen menu in the upper left corner of the model.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
j.palmeL29YX
EXPLODE command
Jürgen Palme
czaborowski
Observer
Observer
Here's an out of date example I'm talking of.
j.palmeL29YX
We are here in the AutoCAD forum.
The native AutoCAD can not handle with .stl files.
For more information search in the forum for ".stl file" or similar - you will find more detailed answers.
Jürgen Palme
SEANT61
The Solid Editing functions with an AutoCAD 3D Solid
May your cursor always snap to the location intended.
