AutoCAD Forum
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Each dwg file opens a new Autocad
2 REPLIES 2
sebulbaQN622
245 Views, 2 Replies
sebulbaQN622
Good morning,
I was installed Autocad 2023.
The problem I encounter is that every time I open a dwg file, the file opens in a new Autocad.
I checked the SDI variable which is indeed 0.
Any idea how to solve this?
THANKS ๐Ÿ˜‰
Good morning,
THANKS ๐Ÿ˜‰
2 REPLIES 2
cadffm
in reply to: sebulbaQN622
cadffm
and your .dwg extension is linked to the aclauncher?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Double-clicking-a-...
Sebastian
Sebastian
sebulbaQN622
sebulbaQN622
It's works now.
The link to acad.exe was wrong because linked to old Autocad.
Thank's for your help ;oi)
It's works now.
AutoCAD Inside the Factory
