dynamtic text copy paste solve
Y_q_12Z64F3
Message 1 of 18
Y_q_12Z64F3
dynatic text block text cilck copy after text paste {\{\urtf1\ansi\ansicpg65001\deff0\deflang1033{  this text fail?
Replies (17)
Message 2 of 18
TheCADnoob
How are you copying the information? Are you clicking copy or using a keyboard shortcut?
This string "{\{\urtf1\ansi\ansicpg65001\deff0\deflang1033{" is some form of text formatting.
Can you provide screen shots?
CADnoob
Message 3 of 18
paullimapa
Any reason for not using the standard Copy command?
If want in another dwg how about wblock the text from dwg and then insert block exploded in the other dwg ?
Paul Li
IT Specialist
@The Office
Message 4 of 18
Y_q_12Z64F3
DWG AND VİDEO ADDED @paullimapa @TheCADnoob
Message 5 of 18
cadffm
Not on my side..
Test1: PASTE it in WORD, same issue?
Sebastian
Message 6 of 18
cadffm
Test2: Please try the same in another Dialog, like STYLE [New...] copy the Style name and paste it..
same issue?
Sebastian
Message 7 of 18
yunusemregokyildiz7YYB7
yes
Message 8 of 18
cadffm
Just guessing:
Are you running AutoCAD FOR MAC or AutoCAD (for windows) on MAC, or by remote?
If not: Perhaps you are using special settings for the system text (fonts, size, etc.),
but I have no idea about these possible connections,
this is just a wild idea.
Sebastian
Message 9 of 18
Windows 10 Pro for Workstations pc computer
Message 10 of 18
paullimapa
What AutoCAD version?
Run About command, do a screenshot and share that here
Paul Li
IT Specialist
@The Office
Message 11 of 18
Message 12 of 18
paullimapa
Oh you’re on the wrong forum
you should post here:
https://forums.autodesk.com/t5/autocad-plant-3d-forum/bd-p/371
Paul Li
IT Specialist
@The Office
Message 13 of 18
SAME 3D AND 2021. IT DOESN'T MATTER
ADDING VİDEO
THX
Message 14 of 18
paullimapa
Problem could be this 2021 is the original release with none of the updates applied
see version list here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-tie-the-Pro...
Paul Li
IT Specialist
@The Office
Message 15 of 18
pendean
Community Legend
Community Legend
This might be either a P3D issue or a 2021 wit no updates installed issue, I can copy paste just like in your video in plain AutoCAD 2023 just fine here
But this one is multi-line, aka MTEXT, and it may have overrides
Although, again, it copy/pastes just fine in AutoCAD 2023
And then... when I open and do the same in P3D 2023.0.2 (aka fully updated) I also have no issues
So you either need to make an effort to update your 2021 software
https://manage.autodesk.com/products/PLNT3D?version=2021&platform=WIN64&language=EINT
Or upgrade to a newer P3D?
Message 16 of 18
TheCADnoob
I cannot duplicate your problem.
For some reason, it is copying the RFT formatting from the textbox control in the Attribute dialog.
when you enter the text editor, however, you are not interacting with a textbox control, so it doesn't copy the RTF.
Have you added any clipboard modifications to your system? Do you have any plugins installed in AutoCAD?
CADnoob
Message 17 of 18
Y_q_12Z64F3
Message 18 of 18
TheCADnoob
That's a fantastic Find! Thanks for sharing
CADnoob
