Hello, I have an issue with the dinamic dimensions.
After I close or save, Pro A 3D (it does the same on Autocad 2022) dimensions disappears and i can't even change them anymore. It doesn' happen every time, but it happens really often.
See attached:
As you can see in file 1 there aren't as many dimensions as 2
In file 2 you can see that there are dimensions, but only if I select everything
If I share the file, the dimensions just deletes and I can't see them even if I select everything..
I have already tried RIGENT but it doesn't work
-moderator edit: corrected spelling error in title.
