accoreconsole modifies the logfilepath
Peter2_1
Peter2_1
I defined accoreconsole.exe to use "/p myprofile" where the logfilepath is set to "f:\somewhere\logs".
But when I start accoreconsole with "my_roboter.exe", accoreconsole uses "myprofile", but it always changes the logfilepath to the path where "my_roboter.exe" is stored. At the end of the job, the logfilepath is reset to the original value.
What's the reason behind it?
Can this be changed?
Thanks and regards!
AutoCAD Map 3D 2023 German / Oracle
cadffm
>"I defined accoreconsole.exe to use" how?
Show your usual start string,
show the start string use in my_robot.exe
at this point you should see a difference.
If you are using the same strings:
All tests done by Acad open or all test done by closed Acad?
If not, test it again by the same environment (Acad open, OR Acad closed)
And if you are talking about the logfilepath only, why not changing as first step of your script?
Thats the way I use it often because different jobs needs often  differently logfilefolders (on my side).
Sebastian
Peter2_1
Hi @cadffm
thanks for your detailed reply. At the moment I have to finish other jobs, so I have to postpone this topic. I will come back later.
