Dynamic Block with Repeating Field
I am working on developing a matchline block for large sheet sets. I am trying to simplify this process by creating a block that has all four matchline labels inside of the matchlines. In the center of the block is a large attribute that would be the sheet number and it is on a non plot layer. Now I need the four matchline labels to use the same sheet number so that I only need to change the sheet number once (which is an attribute that uses a field to reference the proper sheet once placed). Any thoughts would be greatly appreciated?
leothebuilder
Use a field to replicate the attribute's input, and copy this field 3 or 4 times as needed
