07:43 AM
I am trying do define a dynamic block which contains an array function. This function should be able to perform 2 dynamic input: 1. adapt to the length of the rectangle 2. divide the length into equal pieces I was able to ad an array to a stretch so point 1 above is no problem. I am able to define a fixed increment in the properties (during BEDIT) but i can't find a way to make this an editable value when using the block. Is there a way to make the increment value a modifiable value so when i am using the block, i can edit this (e.g. choose if increment is 150 - 200 -250) Thank you for your ideas. PS: this post might be in the wrong location, but the selection window doesn't seem to let me pick any other location.
