dynamic block: array with definable increment distance
I am trying do define a dynamic block which contains an array function. This function should be able to perform 2 dynamic input: 1. adapt to the length of the rectangle 2. divide the length into equal pieces I was able to ad an array to a stretch so point 1 above is no problem. I am able to define a fixed increment in the properties (during BEDIT) but i can't find a way to make this an editable value when using the block. Is there a way to make the increment value a modifiable value so when i am using the block, i can edit this (e.g. choose if increment is 150 - 200 -250) Thank you for your ideas. PS: this post might be in the wrong location, but the selection window doesn't seem to let me pick any other location.
Sofia.Xanthopoulou
Hi @Anonymous,
and welcome to the Forums.
I might have understood what you are looking for, but to be sure.. can you please send over a drawing with some notes on what you are looking for.
Thank you
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Hello Sofia,
in attachment you will find a dwg with 2 dynamic block. (rectangle with a strecth funtion)
 Below: block with an array set with colom distance 150mm
 Above: block with an array set with colom distance 200mm
In these blocks I can change length (distance1) and the array function adapts along with this parameter. But I would like to be able to also change the distance between coloms (in the block properties). This way i do not need to make diffent dynamic blocks for each different array setting needed.
Sofia.Xanthopoulou
Hi @Anonymous,
your approach is good!
But I am afraid I have to disappoint you about the input of the spacing in a dynamic block with an array. The moment you create an array action you are required to type in a number - nothing else is allowed. So no way you get a parameter in there.
Do you really have to use dynamic blocks?
Please take a look at my suggestion. I have used constrains and parametric dimensions. It works similar to your example, plus you can edit the spacing of the array. There is one tiny issue I am struggling with... The amount of the columns. There is something wrong with my equation Smiley Sad. But at this moment this is the best I could come up with.
I have attached my drawing, so you can follow my steps.
Do not hesitate to ask, if you need further assistance.
Regards
I am not very familiar with constrains, but it opens some new possibilities. I will look into it. Thank you for your input!
I love what you did. But can you show how you did that?
I would also like to se how you were able to do this.
