AutoCAD Forum
Dynamic block and parametrics
3 REPLIES 3
293 Views, 3 Replies
Can I create a variable that has the same value as a user parameter. Eg, if I create a user parameter named length with a value of 200 can this change a variable which I can then link to a stretch command in a dynamic block?
This is because I need to have a number of dynamic blocks in a drawing which have dimensional constraints between them and other geometry.
3 REPLIES 3
pendean
DynBlock forum is here http://forums.autodesk.com/t5/dynamic-blocks/bd-p/154
It would help them a lot if you posted a sample DWG file with the content you describe.
Well after some searching I can get round what I need to do with some diesel expression if its possible....
Is there some expression to retrieve the value of a specific parameter. I need to get the value of the parameter "width". It only needs to display the value nothing else.
pendean
FIELD command has a custom option if the presets don't meet your needs.
AutoCAD Inside the Factory
