I am using autocad 2012 paired with Aerotech A3200/Cadfusion to create a 2D toolpath. Most of the objects I make are filled shapes (rectangle, circle, etc). I would like to make fill in the objects with hatches, because it is much faster than the array tool. The problem I keep running into is that the hatch disappears in CadFusion because the hatch lines aren't considered entities.
Solved by Emmsleys. Go to Solution.
I don't have much experience with CADfusion but have you also posted this in the CADfusion forums as well?
How is it when you bring a drawing over from CADfusion into AutoCAD do you have the same issue?
Following up on your thread, were you able to find a solution?
Are you able to provide more information?
Post back with any new updates. Thanks.
Have you tried using explode so it is no longer a hatch and just lines and arcs and polyarcs?
I have had to do this before with text and a few other things
