DXF text output
DXF text output
m552471
Observer Observer
Message 1 of 10
DXF text output
m552471
Observer
Observer
Can someone tell me if there is a text or dxf variable that i can change to prevent the below image (attachment) from happening? my laptop was a straight replacement as my old one dies suddenly, so my commands and files didn't transfer over to my new laptop. basically it was a brand new install vs a transfer. my thought is that a "variable" was set on my old laptop that i have since lost. im using AutoCAD 2019
Replies (9)
Message 2 of 10
imadHabash
Hi and Welcome to AutoCAD Forum,
i think that you may need to check if there is a lost font that your text style need.
Regards.
Imad Habash
Message 3 of 10
Moshe-A
@m552471  hi,
if you set CANNOSCALE to 1:1, does it go away?
moshe
Message 4 of 10
m552471
Observer
Observer
that seems to be the default setting. it is set to that. same result
Message 5 of 10
Moshe-A
then it's sometning got to do with the font, change it to some other common you use to.
Message 6 of 10
pendean
Community Legend
Community Legend
Pictures only show symptoms: how abut posting your DWG/DXF file with the problem instead.
Message 7 of 10
m552471
Observer
Observer
our annotation uses Arial Narrow size 6. when the dxfout command is prompted, the file looks and appears to be normal in autocad. when that same file is imported into a JDA application (floor planning) the JDA program doesn't support arial narrow and converts it into simplex. thats not the problem. the problem is it throws all the text in the lower left hand corner. it never done this before until i received my new laptop. thats why i feel its an AutoCAD variable. we have other laptops in the office that have not been replaced and the command works fine especially when importing into the other program.
Message 8 of 10
pendean
Community Legend
Community Legend
if I may ask: why not use SIMPLEX in your drawing and control the location/appearance, does that change the behavior in the other program?
Message 9 of 10
________________________________________
Dafont Showbox FileHippo
Message 10 of 10
m552471
Observer
Observer
no same result
