DXF read error Invalid or incomplete DXF input -- drawing discarded
Need some help! I get the error "DXF read error Invalid or incomplete DXF input -- drawing discarded" once in awhile.
I have a file Id like not to lose. Any idea how to recover it?
Any ideas as to why this happens?
Need help! On the occasion I have been getting the error "Invalid or incomplete DXF input -- drawing discarded, Press ENTER to continue"  Not sure why this is happening.  Any ideas on a fix?
pendean
Community Legend
Community Legend
"on occasion" and "once in awhile" are too random for a guaranteed fix: the errors only indicate you have a bad DXF files.
What is the source of the DXF files? What is the content of the DXF files?
"once in awhile" is the best way to describe it....I cant really say what I do different that would cause the "error".  I do hundreds of these type of drawings and I get one every now and then that does this to me where I can not open it.
The file is just a simple drawing (car part, nothing 3D or crazy).  I have the file I can send if that'll help.
fatal.error
Have you created the DXF with AutoCAD? Have you tried the RECOVER command?
Do you know the exact line-number where it fails? If so, you could open the DXF with an editor such as Notepad, Notepad++ or Visual Studio Code and inspect the informed line.
DXF file structure starts like these:
    0
  SECTION
    2
  HEADER
and ends like these:
  ENDSEC
    0
  ENDOF
If EOF line (End Of File) is missing, the data never completed writing to the file.
Common causes are:
  • The DXF file was created by an external application but it doesn't have a proper format matching the DXF specification.
  • The file was created as an export from a corrupted (e.g. non-Autodesk) DWG file.
  • The file was damaged during transmission or during copying.
  • It is not a DXF file, but e.g. a renamed DWG file.
  • The DXF file was edited in Word.
  • The DXF file is not stored in the ASCII or UTF-8 (w/o BOM) format.
To get further assistance, you should zip and upload the corrupted file.
Further reading:
AutoCAD DXF Reference
Writing a DXF file
