Announcements
Dwg to pdf print is bad
malinateodorarugea_stud23
Message 1 of 10
Community Visitor
Community Visitor
So randomly this problem appeared. When I print or drop the pdf to photoshop to edit it a bit I see that the solid hatches have white lines all over them and the lines with transparency are way too faded. This problem isn't only with my last project, I tried to upload old projects that were ok before and they do the same thing now.
Replies (9)
Message 2 of 10
paullimapa
I'm not getting lines with solid hatches from AutoCAD PDF when opened in Photoshop.
Here are my dwg, pdf & pdf samples.
AutoCAD drawing:
AutoCAD PLOT window:
PDF:
PSD:
Paul Li
IT Specialist
@The Office
Message 3 of 10
Community Visitor
Community Visitor
Ok so it seems yours almost work, bit of lines in the solid hatch. I still cannot understand why my files look so bad. Indeed I plot on bigger formats and have other settings. Take a look. In this one I don't have examples of the transparency problem but the hatches are enough to tell me it's still not working. Also when I create new files with simple geometry it still doesn't work. When I send this pdf to another computer it does the same so the problem is rooted clearly in autocad software. Also your pdf is working good.
Message 4 of 10
paullimapa
I see when the problem with solid hatches occur.
When there is an odd shape or rotated then Photoshop has a hard time rasterizing the solid pattern.
When there's a rectangle that's orthogonal then the solids are read well in Photoshop.
Acrobat on the other hand has no problems showing the pdf keeping it as a vector file:
In AutoCAD dwg I introduced these 3 shapes in the middle with Solid hatches:
Printed to PDF Acrobat views these 3 Solids as vector perfectly:
But Photoshop when rasterizing the pdf causes these angle lines to appear:
Paul Li
IT Specialist
@The Office
Message 5 of 10
DGCSCAD
I've gotten around that issue by copying the solid hatches in place then changing the newly created solid hatch angles to 90 (perp to originals). It's just a quick fix but it works.
AutoCad 2018 (full)
Win 11 Pro
Message 6 of 10
paullimapa
glad you found a solution...cheers!!!
Paul Li
IT Specialist
@The Office
Message 7 of 10
Community Visitor
Community Visitor
Yes it appears that the orthogonal shapes don't have a problem. Thank you so much! Also I guess the problem with the transparency is that it gets a bit lighter in photoshop and I could just adjust it from autocad making it a bit less transparent or edit the contrast straight from photoshop. What it weird is that I didn't have this problem before, is there a reason?
Message 8 of 10
paullimapa
not sure how far back this problem may have started since I don't use Photoshop to read back pdfs created by AutoCAD, I can't tell you.
Paul Li
IT Specialist
@The Office
Message 9 of 10
Community Visitor
Community Visitor
Thank you!
Message 10 of 10
Brock_Olly
I've also seen horizontal white lines on hatches on many pdfs, on many different programs.
Quite annoying but I tend to ignore it.
Example of a rounded arrow with solid hatch infill:
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
