dwg to pdf: plot documents in cad and the result is an image, not a vector file
emiranda948
Observer Observer
Message 1 of 10
emiranda948
Observer
Observer
I work on autocad and I plot the drawings to pdf so I can work on illustrator. Time ago when I used to import the pdf files to illustrator the lines were vectors and I could edit them, now i plot the file and the result is only a rastered image, and I can't edit it properly.
I know is something on cad, maybe the configuration or something, but I don't know what to do!
Please help me!
Replies (9)
Message 2 of 10
chriscowgill7373
if you are plotting with transparency or have the check box marked, you'll get a raster image, not vector.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 3 of 10
john.vellek
Hi @emiranda948,
I believe that @chriscowgill7373 is correct that transparency has probably been turned on.
When I send DWGS to Illustrator I don't even bother with the PDF. I save a copy of the drawing down to an older version [EDIT (2007 in my case)] and then open the resulting file directly in Illustrator.
Another method is to use EPSOUT to create an encapsulated Postscript file.
John Vellek
Message 4 of 10
gotphish001
What does saving down to an older version do? Just make objects blocks?
Nick DiPietro
Cad Manager/Monkey
Message 5 of 10
rkmcswain
john.vellek wrote:
.... I save a copy of the drawing down to an older version (2077 in my case) and then open the resulting file directly in Illustrator.
You may need a flux capacitor to get there however.... Smiley Wink
Message 6 of 10
chriscowgill7373
Obviously I'm not John, but Illustrator may not be able to open the newer dwg formats yet, saving down gets by that.
Message 7 of 10
emiranda948
Observer
Observer
Thanks for your answer, but I plot without plot transparency and i still have the same problem 😞
Message 8 of 10
emiranda948
Observer
Observer
Hi!
Thank you for your answer.
I don't have activated the transparency when i plot, and there is the same problem
i've never tried to import to illustrator directly from dwg, i'll try it now, also the encapsulated file
but i guess something is wrong with Autocad, because i used to plot like that time ago and it worked, maybe with the update something went wrong 😕
Message 9 of 10
john.vellek
HI @emiranda948,
What driver are you using to create your PDF when you plot? Can  you etransmit a sample file for me so i can try it too?
John Vellek
Message 10 of 10
chriscowgill7373
what driver do you use to plot your pdf?  could you post some screenshots of your plot dialog box and settings for the pdf plotter?
