I have setup Page Setups for a very long time.
But I ran into a really weird problem for a firm last week.
They upgraded to 2018 and I came in and copied the plotters for AutoCAD 2018 into their Plotters folder and started redoing the page setups.
All of them work except when using page setup overrides to plot to PDF.
They get a warning saying PDF Could Not Be Repaired.
I tried both the DWG to PDF.pc3 file and the AutoCAD PDF (High Quality) which I have used successfully before.
The only one that worked is the driver for PDF Converter Professional 8 by Nuance.
And the problem with that driver is that you have to load custom pages at each person's computer.
What in the world could be the problem?
Because when Adobe Reader is the default, the same problem occurs. DWG to PDF.pc3 file and the AutoCAD PDF (High Quality) both still do not work.
