DWG to PDF color change
boris.z
Message 1 of 18
boris.z
Hello, i'm using autocad 2018.
When i print to pdf and the green lines in the pdf are brighter (not so dark).  The green color change from the preview to the pdf. I) tried to use like green, the color book likefor exemple DIC 250 , and everything all right but when i come back to use the index color the same thing.
I print with check: - Plot object lineweights  - Plot trasparency  - Plot paper space last.  I tried to uncheck the last two but isn't the same green.
Seems that the problem is with all other index colors, because i tried other colors..
In the files attached, the color that change more is the green, but i tried other color and it's the same.
It's really strange
Sorry for my english
please some help..
Replies (17)
Message 2 of 18
Alfred.NESWADBA
Are you using a CTB or STB file? If so, change that to nothing in the plot-dialog.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 18
boris.z
i think i'm using ctb file because in the plot style table there are only ctb styles.
i tried to put on "none" but the result it's the same.
So if i work with layer and thikness on any layer i must use onlu stb file to have the right result between autocad and pdf?
i see now in youtube that there is a command "convertpstyles" and when i go to select the stb file auto cad tells me "acad.stb  does not contain a color mapping table and cannot be usedto convert drawings. select a different named plot styles"  i tried to select the other 3 stb file in the folder that gave me , but it's the same message.
Message 4 of 18
Alfred.NESWADBA
Can you upload a DWG-file as well as a PDF-file you get from your plot command/-settings? ... just to see if we can reproduce that behavior.
- alfred -
Alfred NESWADBA
Message 5 of 18
boris.z
Of course thank you.
Olso i tried to open stb (named plot file)  and use the same 92 green color and itìs the same thing, it's a lighter green.
If i use the book color, seems work fine, but with the index color don't.
Message 6 of 18
Alfred.NESWADBA
I can see the difference between the green on the layout (in AutoCAD) and the green in PDF, however I have no idea for now what makes up the difference ...
Maybe someone else has an idea or the time gives me some inspiration ... 😉
Sorry for now, - alfred -
Alfred NESWADBA
Message 7 of 18
boris.z
Thank you. I will wait.
Maybe i have to reinstall auto cad...
Message 8 of 18
Alfred.NESWADBA
Definitely not, because I have the same behavior on my system.
- alfred -
Alfred NESWADBA
Message 9 of 18
boris.z
You're right...  maybe my autocad is corrupted.. i don't know, and maybe generate corrupted files.....
can you try with your autocad with the same color on a ctb new file.. i alwayse use them with my layer work... (and i put "none" to the plot style)
Message 10 of 18
Alfred.NESWADBA
No, it is not.
I have created (AutoCAD 2019.1.2) a new dwg-file, created one polyline with color 92 and in creates a much lighter green in the PDF. So it's nothing specific to your system.
- alfred -
Alfred NESWADBA
Message 11 of 18
boris.z
it's really strange...  i tried with a lot more color and when open in adobe acrobat a lot of the colors are not the same... Maybe is a limit this of autocad (hope there is a reason) .....maybe because i'm using adobe acrobat and this program read the color in different way..?!  maybe if i print the file,  the colors are fine ( i didn't tried because i don't have a big printer).
Message 12 of 18
cadffm
Please post some more color numbers for us, thx.
The Problem is NOT the pdf or plot result, the problem is on editors side if the backgroundcolor is not set to black.
Use background black for a test. Options/Display/Colors..
Sebastian
Message 13 of 18
boris.z
Hi, thank you. is seted to black , the background in the model space. But it's the same problem (i olso tried to make DPI 400/500 but not change)
Message 14 of 18
cadffm
" the background in the model space. "
nice, but you misunderstood.
You set your modelspace background to black, ok (so the color displays there well),
but your screenshot is from layout-tab and there is your background color not black,
it is white or near to.
As i wrote..
"the problem is on editors side if the backgroundcolor is not set to black.
Use background black for a test. Options/Display/Colors.."
Sebastian
Message 15 of 18
boris.z
with the black background in the plot preview seem the colors are the same but maybe is a visual effect because of the black background. I put olso the background to black in the layout space but it's the same thing.
Message 16 of 18
cadffm
SORRY for tha late edit:
borissss..
Your "first" screenshot shows the paperspace.................with NON-BLACK-BACKGROUND!
and for the third time: As i wrote..
I don't know why and we can not change it,
but i can you explain how you get the right color displaying on screen and when not.
Only with a black background..
In your next answer, write:
@ john.vellek
But without a blank after the @, he is from Autodesk and perhaps he has answers (but no solution in this case).
Sebastian
Message 17 of 18
boris.z
Sorry, i put now the black background. It's the same thing.
When i press plot preview the bacjgorund is grey but this color i don't know how to change.
Message 18 of 18
cadffm
I can not see the properties of your sample file (easy to share with us),
but the background color for model,paperspace and plot preview are reachable via
Options display colors.
And alle three displays the color well (only?) if the background is set to black.
But that knowledge change nothing.. or do you want to work with all backgrounds are set to black?
I am out.
Sebastian
