DWG to FBX - 2019/2020 - Twinmotion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Since Autodesk chose to put away the practical and logical feature FBX Export/Import from AutoCAD 2019 and 2020, I’ve being struggling with attempts to export my 3D models (solids) from AutoCAD to Twinmotion properly.
When I choose to export the 3D model from Infraworks, it goes OK in terms of scale and spatial position (original coordinate system) but messes with the model itself, changing the triangulation behavior.
I’ve tried to use 3DS Max and Navisworks, both using the corresponding unit from the original DWG, without changing the original geographical reference, but when I try to import those on Twinmotion, it goes all crazy both on scale and spatial position (random coordinate system) , not being able to find the correct correlation to fix it.
Here on the Forum people were talking about a palliative fix that Autodesk provided (AutodeskAutocadFBX2019_64.exe) but is now offline…
Thinking as users and not employees, are you guys experiencing difficulty with that ‘consuming more products’ policy or found another solution to bypass this horrible workflow to get a simple FBX out of 3D solids?
Thanks!
