Dwg file
Dwg file
Dwg file
Hi.
Is there any way to make a dwg file that only works for example 1 week and that after 1 week it is not possible to open the dwg file?
maratovich
In AutoCAD, no.
But you can use additional methods to protect files and make access on time.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Alfred.NESWADBA
may I ask the reasons for such a workflow? Why would anyone want to lose data/work he/she did?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Hi.
thanks for the repet. Can you please give me som pointers on what i can use?
The reason is that the DWG file is a drawing That shows sensitiv info on a plant. The DWG is to be sendt to a supplier and we do not want them to have unlimited access.
-Bjørn-
Alfred.NESWADBA
Well, if you send the data the partner can then open the dwg-file, use copy & paste to copy the content of the geometry into a new drawing. So it is irrelevant if the original drawing is self-destroying after some time.
Either send the data (as PDF or whatever) + the license agreements/contract for "what is allowed", that's how you can protect your work.
- alfred -
Alfred NESWADBA
Hi.
That is true. Thanks for the reply annyway.
