DWG file No Preview Available in Windows Explorer
aliu
Message 1 of 15
aliu
Help please.
I lost the DWG file preview in windows explorer after I installed the eDrawings viewer
Autocad 2019 installed,
I tried to uninstall eDrawings, it did not help to recover the preview.
The preview was good before the eDrawings installed.
Thank you in advance.
Replies (14)
Message 2 of 15
imadHabash
I suggest to make sure Windows is set to display thumbnails . Folder options >> View tab .
Imad Habash
Message 3 of 15
aliu
Thank you for the reminder.
Yes, the Preview Pane is ON.
The PDF file has a preview in Preview Pane.
Message 4 of 15
aliu
my current setting
Message 5 of 15
JTBWorld
There is probably a registry hack for this but other than that repair AutoCAD should fix it.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 6 of 15
aliu
Thanks.
This happened only after I installed eDrawings.
I would not like to uninstall / reinstall Autocad because there are lots of customized settings and addins.
Message 7 of 15
JTBWorld
A repair of AutoCAD should not affect your custom settings.
Otherwise this might help: DWG file type associativity in Windows.
Jimmy Bergmark
Message 8 of 15
beyoungjr
Make sure that edrawings is not set as the default program for any of the ACAD file types (dwg, dxf, etc...) .
Blaine Young
Senior Engineering Technician, US Army
Message 9 of 15
aliu
Thanks.
How to check this :
"Make sure that edrawings is not set as the default program for any of the ACAD file types (dwg, dxf, etc...) ."
Message 10 of 15
pendean
Community Legend
Community Legend
@Anonymous look at the link in reply #7 above, that was already shared with you from @JTBWorld
Message 11 of 15
beyoungjr
You can find Windows 10 default program settings by getting into settings-> default apps.
You can also right click a drawing file itself and select "open with", then make sure to fill in the check box for "always us this program" and choose AutoCAD to open that drawing.  The Windows default will be set immediately and you may see icons refresh.  This might restroe the image preview for ya.
Blaine
Blaine Young
Message 12 of 15
aliu
I have tried all above suggestions, including run Autocad 2019 repair. But NO luck so far. Still NO preview for dwg files.
Any other ways to suggest?
Thanks.
Message 13 of 15
pendean
Community Legend
Community Legend
Read this https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/DWG-th...
If everything there does not help, but opening them SAVING a few DWG files fixes only those files previews, then your system is hosed with that 3rd party app. You'll have to start over with using QSAVE on each file moving forward.
Message 14 of 15
j.hunterhilts
Observer
Observer
Anyone have a definitive solution? I have exhausted every suggested fix here and still no DWG preview. I am not getting a "No Preview Available", just a blank preview window.
Message 15 of 15
pendean
Community Legend
Community Legend
If this did not fix it https://forums.autodesk.com/t5/autocad-forum/dwg-file-no-preview-available-in-windows-explorer/m-p/1...
Then...  start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
