dwg appearance/materials
sm3PALG
sm3PALG
When opening a dwg that I exported from inventor the custom appearances show up in auto cad using realistic view. When I send the dwg to another person it loses the appearances and shows as default grey parts. Is there a way to attach or reference the appearances so anyone opening them in another location will be able to see the appearances ?
vinodkl
Different appearance can be changed with visual styles. Use command  VSC and change it to realistic view.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
