Duplication of objects in a block
jchoppen
jchoppen
I have noticed that some objects (polylines, leaders, inserted standard non dynamic blocks) have become duplicated in a dynamic block and I do not know the reason for this. I noticed it when I switched on selection cycling.
If I look at a backup of the file (a stored .dwg not a .bak) from a few days ago there are not duplicated items in the block and the only changes I have made is to rename some layers and adjust some leaders in the dynamic block.
I'd be interested if anyone else has seen this, and possibly know a reason.
I am using AutoCAD2020 , Windows 10 Enterprise, and a Dell Precision 44560 32GB RAM
cadffm
In older versions, older than 2022.1.2, like your 2020 is a bug between BEDIT and ISAVEPERCENT,
you should set ISAVEPERCENT to 0
to avoid further duplication.
Sebastian
jchoppen
Many thanks CADffm.
Are there any downsides to setting the variable to 0, apart from 'all save operations are full saves' (taken from ACAD help) ?.
I also see that from the Help that '..automatic saves are incremental, temporarily overriding the value of ISAVEPERCENT with a value of 90.'   Do yuo know if this means that  during an automatic save it will be set to 90 and duplication of objects could still occur ?
cadffm
>>"Are there any downsides to setting the variable to 0"
No, the only thing is - it takes more time. (if you working with big files, much edits and a really slow save-location, you will recognise it)
>>"Do yuo know if this means that  during an automatic save it will be set to 90 and >>"duplication of objects could still occur ?"
Sure! But
1. the issue doesn't appear by saving, it appears by using audit or recover such a file - Usual open command without a recover will not create duplicates.
2. for usual you don't work with "automatic saved files", for usual you are working with .dwg files which you saved - and in this case acad is using your setting (0, not 90)
Sebastian
jchoppen
Many thanks (and also a thanks for the thoroughness in you other Post that you included a link to). I haven't fully 'processed' your answer yet (I am relatively new to AutoCAD), and I was going to do some bench testing but can see that now in your other post.
ktabanin13
I can't thank you enough for this insight!
