Duplicate DWGs
Duplicate DWGs
jbeckW3VSP
Observer Observer
Duplicate DWGs
jbeckW3VSP
Observer
Observer
DWG resaves duplicate dwg when multiple users are in dwg at once. How to make all drawings read only when in use?
paullimapa
sounds like your network operating system is failing to do its job to lock users out when another has the file opened
Paul Li
IT Specialist
@The Office
Valentin_CAD
@jbeckW3VSP ,
I agree with @paullimapa , contact your network administrator to identify the issue.
Also, make sure you AutoCAD is current with the updates.
Otherwise, try the same suggestion as if the file was read-only.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
pendean
Community Legend
Community Legend
@jbeckW3VSP Are you by chance relying on a web-based file storage service?
Or a NAS drive?
Read this https://forums.autodesk.com/t5/autocad-forum/multiple-users-opening-the-same-file/m-p/8915151#M98673...
RobDraw
Multiple users in the same file shouldn't happen, ever.
Rob
