Does anyone know how to make this possible in AutoCAD 2014?
I need to build a drop down list of links for some blocks so that when I produce dwfx’s from the sheets the owner can pan over the blocks and select from a list of information he might want to review. I tried linking an Excel drop down into a table, but neither the hyperlinks or the list worked. I also tried putting a column of fields in the blocks but it gets messy on the sheet. I tried placing the fields on defpoints… but then the hyperlinks don’t print. I had read other post on this and other forums, but they were old and I hoped the issue had been addressed. Thank you for your reply.
thanks, I will try to host the hyperlink to something that is small enough not to be a distraction when printed.
Found a way... just wish there was some way to get it into a PDF. Dwfx's work beautifully but Autodesk does not provide a viewer for the IPad or Mac that is not web based. Sometimes on construction sites there is no access. Any suggestions?
