Message 1 of 8
Draworder Problem
07:07 AM
*****WHY WHEN I GO TO POST A NEW TOPIC TO A BOARD, MY LOCATION SELECTION OPTIONS ARE ONLY FOR FRANCAIS OR DEUTSCH????**** Hello, I am having trouble using Draworder. I just installed Autocad 2010 (full version. Not LT) on a fresh install of Windows 7 (All Windows updates up to date). Ive been using Autocad 2010 for 5 years and have installed it multiple times on different Windows 7 machines and never had this issue. Everytime I click the Draworder button or type the command in, I get Unkown command "DRAWORDER". After some googling, I tried loading the acdorder.arx file with no luck. Here is the syntax that the command line is pumping out: Command: Draworder Unknown command "DRAWORDER". Press F1 for help. Command: appload acrxGetApiVersion not found in C:\Program Files\AutoCAD 2010\acdorder.arx Make sure the app links with rxapi.lib and export the symbol.AcRxDynamicLinker failed to load 'C:\Program Files\AutoCAD 2010\acdorder.arx' C:\Program Files\AutoCAD 2010\acad.exeUnable to load acdorder.arx file. Any help would be appreciated!!
