Draworder Problem
Draworder Problem
Message 1 of 8
Draworder Problem
*****WHY WHEN I GO TO POST A NEW TOPIC TO A BOARD, MY LOCATION SELECTION OPTIONS ARE ONLY FOR FRANCAIS OR DEUTSCH????**** Hello, I am having trouble using Draworder. I just installed Autocad 2010 (full version. Not LT) on a fresh install of Windows 7 (All Windows updates up to date). Ive been using Autocad 2010 for 5 years and have installed it multiple times on different Windows 7 machines and never had this issue. Everytime I click the Draworder button or type the command in, I get Unkown command "DRAWORDER". After some googling, I tried loading the acdorder.arx file with no luck. Here is the syntax that the command line is pumping out: Command: Draworder Unknown command "DRAWORDER". Press F1 for help. Command: appload acrxGetApiVersion not found in C:\Program Files\AutoCAD 2010\acdorder.arx Make sure the app links with rxapi.lib and export the symbol.AcRxDynamicLinker failed to load 'C:\Program Files\AutoCAD 2010\acdorder.arx' C:\Program Files\AutoCAD 2010\acad.exeUnable to load acdorder.arx file. Any help would be appreciated!!
Replies (7)
Message 2 of 8
patrick.emin
Hi, we experience a technical problem when posting from the main forums page. Please, when creating a new thread, use the following method: find the board you want to post into, go to that board, then post.
Note: this thread has been moved form the french AutoCAD forum
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Message 3 of 8
TheCADnoob
Message 4 of 8
The instructions are a little vague for me. I don't understand what it wants me to do.
Message 5 of 8
TheCADnoob
it offers two potential solutions. The first one. Copy everything that is in red below
(load "acad.mnl")
Then paste that into you command line.
Hit enter to execute the command.
Then try using the DRAWORDER command again.
If that doesn't work we can move on to the next suggestion.
CADnoob
Message 6 of 8
Kent1Cooper
@Anonymous wrote:
.... I just installed Autocad 2010 ....
[This is not the correct Forum for 2010 versions.]
Kent Cooper, AIA
Message 7 of 8
pendean
Community Legend
Community Legend
repair reinstall 2010 and ensure it is fully patched/updated.
Message 8 of 8
Discussion_Admin
This is normally due to java scripts being blocked
Please make sure you are not blocking scripts from Lithium.com, Autodesk.com or Addthis.com ( s7.addthis.com) they are need for all features to work.
also please make sure you are using the latest releases of the supported browsers below (with JavaScript enabled😞
Chrome
Firefox
Internet Explorer 8*, 9, 10 or 11
Safari
Microsoft Edge
For a consistent and reliable mobile device browsing experience, we recommend using one of the latest popular mobile operating systems and devices with their default browsers (with JavaScript enabled):
iOS with Safari
Android with Android browser
Opera Mini
Blackberry Browser
*Note: Internet Explorer 8 is no longer supported on the Community after 7/23/2015, IE 8 users may have a degraded experience. Users with IE 8 on Windows XP may not be able to connect at all to the community
Discussion_Admin
