Drawings or PDF NTS
Drawings or PDF NTS
Message 1 of 16
Drawings or PDF NTS
I converted a drawing to PDF. When I scaled it to 1:20 before saving as a PDF, upon printing a wall of 3m now measured 2.6m. I wondered if this was because of the conversion, so I printed it straight off as a CAD drawing, still not to scale? I wondered if it was because of the tab? I made a new tab in A4 and printed the drawing off, still the same size and NTS? I used my normal approach in viewport, Z then XP, then 0.05 for 1:20, but still not coming out to scale. Even if I could get the scale right it CAD, at the very least, I could print the drawings off and trace over them on my drawing board rather then having to start all over again and draw from scratch. Anybody know why they are not coming out to scale, in CAD and PDF format?
Replies (15)
Message 2 of 16
Alfred.NESWADBA
Please, never scale a geometry. Simply create a layout, create one or more viewports and assign these viewports the scale you want to have, then run command _PLOT and select a PDF-device like "DWG to PDF.pc3".
I don't know what "NTS" means.
Please upload the dwg-file and the pdf-file you get as a result.
For now I don't know, if
  • your dwg-layout/viewport is wrong, or
  • your PDF is wrong, or
  • printing the PDF is wrong (wrong settings like automatic fit to page), or
  • your method you measure the PDF content is wrong
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 16
Not To Scale (NTS). I just tried again to save it as a PDF, you can physically see that the drawing is too small if you put your scale rule on a sheet of A4, if the drawing were to scale at 1:20 it wouldn't quite fit on the page. So even if you scaled it down, it still would not be properly to scale. Originally, I had it printed off at A3 and a 3m dimension only measured 2.6m. Scale still not working. I tried printing it off at 1:1, but you can see it is not right, now my cartridge has run out I've ordered a new one.
Message 4 of 16
Alfred.NESWADBA
can you please upload the dwg-file too?
- alfred -
Alfred NESWADBA
Message 5 of 16
In what format? I have many options.
Message 6 of 16
Alfred.NESWADBA
>> In what format?
If you save an AutoCAD drawing, then the default file format is DWG.
The version of DWG should always be the most current.
- alfred -
Alfred NESWADBA
Message 7 of 16
maratovich
The size of your drawing is larger than A4 (210x297)
When printing, you set the scale to fit.
You need to set the scale to 1: 1.
Or use a utility that automatically calculates the size of the print area.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 8 of 16
I'll attach a DWG file. As far as PDF is concerned, one has the option in plot of DWG to PDF. I didn't use any scale, I did the same as I always do, and it usually saves the drawing as a PDF whatever scale the drawing was.
Message 9 of 16
Alfred.NESWADBA
select your viewport in the layout (the active layout, when I opened your dwg-file, was "A4 Layout").
There you see that the viewport is not set to a correct plot scale:
- alfred -
Alfred NESWADBA
Message 10 of 16
What should the custom scale be then? Why is it set to that scale, I didn't set it to that?
Message 11 of 16
Thanks Alfred!
Message 12 of 16
Also, how do you get to that screen, so I can change it?
Message 13 of 16
Bob_Zurunkle
Just stopping by with a tip - when you do get your viewport scale set properly, lock it!
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 14 of 16
How do you set your viewport scale though?
Message 15 of 16
s.borello
Never scale your geometry... create layouts and assign annotative scales to viewports... see video below.
https://www.youtube.com/watch?v=ppRjgAWhmYU
Message 16 of 16
Alfred.NESWADBA
If you want to plot your part 1:1 then the custom scale should be 1 (in case the plotting units are the same as the units for the model)
Always be careful with "I didn't set that", because it was no one else 😉
A simple zoom in the viewport changes that factor (as long as the viewport is not locked).
What I have shown in my screenshot was the selected viewport and the property window, the property window can be opened/closed by <CTRL><1>
>> so I can change it?
You can change it using the property window (having the viewport selected), or the status line (or with newer versions of AutoCAD the arrow-like grip in the center of the viewport):
- alfred -
Alfred NESWADBA
