AutoCAD Forum
Drawing view scale
9 REPLIES 9
Message 1 of 10
1251 Views, 9 Replies
Drawing view scale
the drawing view gets its scale from the "scalelist" which is no problem.
However if there are xrefs in the drawing the drawing view wants to use all the xref scales as well.
This is a bit annoying when the xrefs have hundreds of random scales in "their" lists.
Is there a way to hide the xref scales?
Drawing view scale
9 REPLIES 9
Message 2 of 10
GrantsPirate
GrantsPirate
-scalelistedit command.  later releases handle this for you in a better manner.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
GrantsPirate
EXPERT ELITE MEMBER
Message 3 of 10
in reply to: GrantsPirate
The scalelistedit only does the scales in the current drawing. my problem is the xref files especially from random sources with 100's of stupid scale factors? it is not always convenient to edit these xref files.
Message 4 of 10
nestly2
nestly2
Do you not have a "Hide Xref Scales" option when expanding the Scale List at the bottom right?  If not, what version of AutoCAD are you using?
Message 5 of 10
Ok this is even more crazy, I have gone through all the xrefs and none of them have the random scale factors in their scale lists? But it’s like there is some legacy where these scales appear as xref scales, even though they have no xrefs?
Message 6 of 10
in reply to: nestly2
Yes that is on the annotative scale list and is switched on! but the "drawing view" scale list is independent.
Message 7 of 10
ok That may have solved it Nestly2, switch to show xref scales then use scalelistedit to delete teh unwanted scales.
Thanks.
Thanks.
Message 8 of 10
Charles_Shade
Charles_Shade
Message 9 of 10
GrantsPirate
GrantsPirate
Depending on  your release there may be a fix waiting for you, like this one for 2010
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13723349&linkID=9240618
GrantsPirate
EXPERT ELITE MEMBER
GrantsPirate
EXPERT ELITE MEMBER
Message 10 of 10
Charles_Shade
AutoCAD Inside the Factory
