drawing sequence
drawing sequence
drawing sequence
Let's say i open 6 drawings.
Im in my main drawing.
Now i go to an other drawing and copy something to put in my main drawing.
I close the other drawing but instead that i come in my main drawing (the one i was in before i copied)
i go automaticly to the next drawing. I don't want this.
Can i alter this?
gr. John V.
RobDraw
No, but there are several ways to shoose the drawing that you want.
Rob
wispoxy
@Anonymous Hold your mouse over AutoCAD icon and it will preview all your projects. Same with Windows 7, 8, 10, and Mac OSX. Applies to AutoCAD 2013, 2014, 2015, 2016, and 2017.
nrz13
Ctrl+Tab and Shift+Ctrl+Tab will toggle through open drawings as well.
I also setup some LISP shortcuts for the SYSWINDOWS command that lets you cascade or tile open windows within the program window.
(defun c:WC ()(command "SYSWINDOWS" "c")(princ))
(defun c:WH ()(command "SYSWINDOWS" "h")(princ))
(defun c:WV ()(command "SYSWINDOWS" "v")(princ))
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
So there is no way to chance it
without doing some extra things.
I wanna thank you for all your answers.
