Drawing random circles
Message 1 of 16
Is there a way of drawing a specific number of random circles inside a rectangle, without having any intersections between them?
Replies (15)
Message 2 of 16
pendean
Community Legend
Community Legend
Nothing automatically does that: are you trying to replicate something you've seen? Show us.
In the meantime why don't you start CIRCLE command and go for it manually while you wait for others to offer ideas.
Message 3 of 16
imadHabash
does those circles have the same radius ? can we have a screenshot example ?
Imad Habash
Message 4 of 16
I could it manually, but I want to draw about 120 circles, and doing so takes a lot of time. The purpose of these drawings are performing different numerical simulations with the parts created, so this should be a more a less quick procedure.
Below, there is an example of what it should look like
Message 5 of 16
Yes, they need to have the same radius.
Here is an example below.
Message 6 of 16
I could also use multiple arrays. However, that makes the circles' distribution more a less standardized, and I don't want that to happen.
Message 7 of 16
imadHabash
You can make your own hatch ( circles ) then convert it ti block then use SUPERHATCH (Express Tool) . click on below image and see how it's work ... 🙂
Imad Habash
Message 8 of 16
RobDraw
Computers have a hard time doing random.
Rob
Message 9 of 16
Is it possible to do that with circles of the same size?
Also, I have developed a code that generates random coordinates within the rectangle. Is it possible to use those coordinates and input them somewhere in Autocad, and use them as the center points of the circles?
Message 10 of 16
RobDraw
Is it truly random or just random enough for this exercise?
Rob
Message 11 of 16
pendean
Community Legend
Community Legend
If you want truly random, you'll have to recreate that manually. Sorry.
If you want a set pattern(see the start of your image) to be crated then you go in to ERASE some circles randomly (similar to the end on your posted image) then you indeed need to use ARRAY followed by ERASE done manually.
Message 12 of 16
Kent1Cooper
Maybe WobblyPline.lsp with its WPL command, available >here<, can at least give you a start.  Draw a Line or Polyline down the middle of the area, and use WPL on it using the EXisting-object option, or you can create the Line from inside WPL.  Give it a really large percentage-of-randomization number, to get it really wackily wobbly.  Here, the blue Line is the original, and I asked for 251 segments [to get 250 intermediate vertices], and 400% randomization:
If the result looks like the vertices would be random-enough locations for your purposes, putting Circles at all the vertices is a trivial coding exercise.
If you don't like the result, you can recall the command and use the Redo option to generate a new wobbliness.  After you've made Redo the current option, you can just hit Enter twice [once to recall the command, once to accept the default Redo option], over and over, to have it try again until you like one.  Some Redo's of the above:
You can also use the PRevious option to have it start over with the same path, but let you change any or all of the other choices [offering what you chose before for each as the default].
The tricky part would be to balance the number of segments and percentage of randomization with the width of the area you want to fill.  And there's the drawback that it can't ensure vertices far enough apart to prevent any of your Circles overlapping, but maybe you could use it as a start and then look through and reposition any that intersect.
Kent Cooper, AIA
Message 14 of 16
leeminardi
I thought I would do some experimentation with an algorithm I was thinking about.  It is easier for me to work in Excel/VBA so I programmed it there with the output a list of circle commands that can be copy and pasted into AutoCAD.
The Excel file looks like this.
r = circle radius
h = the height of the channel that is to contain the circles
theta min = the minimum angl down from the last circle.  The first circle is centered in the channel. An angle of 0 is straight down.  180 is straight up.
theta max = the maximum angle to the next circle
Lmin, Lmax = the minimum and maximum distance to the next circle. the minimum should be at least 2 * r
number of circle = obvious!
The angle and distance to the next circle is calculated and then the result test to see if it is within the channel.  If it is not then another try is made.
When the computation is done you can copy and paste column (from cell F2 down) into AutoCAD.
For these values
here is one solution.
Here's another with the same values
Here's another set of values and results.
The program could be modified to meet additional requirements or rewritten in VLISP.
Here is the Excel/VBA code
Sub main()
' Creates randomw circles.
'LRM  3/15/2021
Range("D2:E1000").Select
Selection.ClearContents
Randomize
Range("b2").Select
r = ActiveCell.Value
ActiveCell.Offset(1, 0).Select
h = ActiveCell.Value
thetamin = ActiveCell.Value
thetamax = ActiveCell.Value
Lmin = ActiveCell.Value
Lmax = ActiveCell.Value
Range("d2").Select
x = 0
y = h / 2#
dx = x
dy = y
ActiveCell.Value = x
ActiveCell.Offset(0, 1).Select
ActiveCell.Value = y
ActiveCell.Offset(1, -1).Select
Pi = 3.1415926535
i = 0
While i < n
    L = Rnd * (Lmax - Lmin) + Lmin
    theta = Rnd * (thetamax - thetamin) + thetamin
    x = dx + L * Cos(theta * Pi / 180# - (Pi / 2))
    y = dy + L * Sin(theta * Pi / 180# - (Pi / 2))
    If i > 1000 Then i = 100
    If y > r And y < (h - r) Then
        dx = x
        dy = y
        i = i + 1
    End If
Wend
End Sub
lee.minardi
Message 15 of 16
leeminardi
@Anonymous   I'm glad you found my program acceptable.
I made a few changes to it including:
  • the program generate a script file that can be run in AutoCAD.
  • fixes a bug that was intended to terminate the program if a solution was not found.
  • redefines the meaning of r such that rmin = 0 means circles may touch.
  • cleans up data typing.
The program may generate circles that overlap. These would have to be manually deletes.  It currently only checks if the next  circle is below 0 or above h.  A lookback feature could be added to determine if the next circle to be added overlaps with a previous circle.  Let me know if you think it would be worthwhile to add this feature.
Option Explicit
Sub main()
' Creates random circles.
'LRM  3/15/2021, revision 1 3/17/2021
'get file name
Dim fn_file As Variant
Dim x As Double, y As Double, r As Double, h As Double
Dim thetaMin As Double, thetaMax As Double, Theta As Double
Dim LMin As Double, LMax As Double, L As Double
Dim i As Integer, k As Integer, n As Integer
Dim dx As Double, dy As Double, Pi As Double
Dim msg As Variant
fn_file = InputBox("Enter file name: ", , "test")
fn_file = fn_file & ".scr"
Open fn_file For Output As #2
Randomize
Range("b2").Select
thetaMin = ActiveCell.Value
thetaMax = ActiveCell.Value
LMin = ActiveCell.Value
LMax = ActiveCell.Value
Range("d2").Select
x = 0
y = h / 2#
dx = x
dy = y
Pi = 3.1415926535
i = 0
k = 0
While i < n
k = k + 1
    L = Rnd * (LMax - LMin) + LMin + (2 * r)
    Theta = Rnd * (thetaMax - thetaMin) + thetaMin
    x = dx + L * Cos(Theta * Pi / 180# - (Pi / 2))
    y = dy + L * Sin(Theta * Pi / 180# - (Pi / 2))
    If k > 100 Then
    i = n + 1
    MsgBox "No solution found." & vbCrLf & "Try using different input values."
    End If
        dx = x
        dy = y
        i = i + 1
        msg = "_circle " & x & "," & y & " " & r
        Print #2, msg
        k = 0
    End If
Wend
Close #2
MsgBox ("File " & fn_file & " has been created.")
End Sub
lee.minardi
Message 16 of 16
@leeminardi Yes, it would be very useful. Also, it would be useful to be able to define the horizontal limits of the rectangle.
