Drawing Properties Custom Properties
Message 1 of 8
Hello everyone,
I updated AutoCad 2019 LT to 2020 LT version and now lost custom properties in all drawings.
When I open drawings in AutoCad 2019 the custom properties still work correctly.
So it’s something with 2020 that is causing the problem.
I am wondering if the function was removed or turned off?
Attached are screenshots.
Thanks advance for any help.
Replies (7)
Message 2 of 8
imadHabash
would you check if the latest AutoCAD 2020 LT update is installed please ?
Imad Habash
Message 3 of 8
Alfred.NESWADBA
you are showing the properties of 2 different drawings, can you please make sure to open the same dwg-file in both AutoCAD releases and verify if you see differences now too?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 8
Hi Alfred,
yes, it is the same dwg, just it is renamed.
And it happens generally on all drawings.
Message 5 of 8
Alfred.NESWADBA
can you please upload a dwg-file that shows dwg-properties in 2019 but not in 2020?
Also please start command _ABOUT and show us a screenshot from that dialog.
- alfred -
Alfred NESWADBA
Message 6 of 8
Here you go.
It is originally created in AutoCad2019 full version but AutoCad 2019 LT open it regularly unlike the 2020 version.
I had to delete the content of drawing and some layouts but the custom property is there.
Thank you
Message 7 of 8
Alfred.NESWADBA
can you please show the _ABOUT screenshot from 2020 too?
That's what I see when I open your dwg with AutoCAD 2020:
- alfred -
Alfred NESWADBA
Message 8 of 8
I did a complete uninstall and reinstalled 2020…and did not migrate the previous settings…it works now.  Thanks for looking into this Alfred…not sure what the problem was.
