I just want to create a line between two different points I have created. However, the points are on a different Z coordinates. So if I start the line at Z = 0 I am being forced to end on Z = 0. Even though the x and y are correct I can't get the second end point to not be zero.
I have autocad civil 3D and am working in 3D modeling.
Solved by Alfred.NESWADBA. Go to Solution.
No, a line can have diffent Z values, speaking about Civil 3D ... also feature lines can have different Z values.
The limitation you might see is if you use polyline instead of line, then yes, a polyline is a 2D object.
- alfred -
