Drawing limits
Drawing limits
Drawing limits
How can I know the existing limits of my drawing sheet?
cadffm
Depending on the selected Plotter, Paper,Plotarea, Plotoffset and Plotscale of your pagesetup
and in some cases: of your paperspace content (if print area is set to Extents).
So it isn't possible to say "look there", but you can set "display paper" and "display printable area" ON
and you will see what you asking for. [Options/Display/  lower left corner]
Or do you want to see it in MODEL tab? Think about 100Layouts in one DWG, which one should AutoCAD show?
There isn't an ootb feature, but search for VPOUTLINE
Sebastian
vinodkl
Turn on the grid display(F7) and open the drafting settings(command "DS") and uncheck the option "Display grid beyond limits" under the "snap and grid" tab. See snapshot
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Kent1Cooper
You can also just type in LIMITS and it will tell you the current values at the lower left and upper right corners in the process of asking for values -- just hit Enter to accept those if you don't want to change  the Limits.
OR, you can type in LIMMIN and it will show the current value of the lower left corner, and LIMMAX the upper right.
OR, you can Zoom  using the Limits to define the Zoom area:
ZOOM
(getvar 'limmin)
(getvar 'limmax)
Kent Cooper, AIA
