Draw Order - Send to Back from the commnd line?
jhdempsey
jhdempsey
Is there any way to send an XREF to the back (Draw Order -> Send to Back) completely from the command line?
(Im guessing I might need to enter some LISP code?)
I have a spreadsheet which runs as an AutoCAD batch processing tool, so need to be able to do everything, including selecting the XREF, from the command line (I run the batch scripts through the accoresonsole)
pendean
Community Legend
Community Legend
-DRAWORDER command (there is dash in the name)
LISP forum is over here if you want help with coding https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
