Draw Order in 2019 Not Working
jserrato25YGE
Message 1 of 102
jserrato25YGE
I'm using AutoCAD 2019. In paper space, I inserted an image that will have text and objects in front of it. When I select the image and change the draw order to be in the back, it works, but as soon as I change tabs, it goes back to being in the front. I've never had this problems in previous versions. Any ideas on why this is happening?
Accepted solutions (3)
Replies (101)
Message 81 of 102
btillett
Kids are the ones that like to get the last word in, even if they are not saying anything. So fee free to retort, i am done.
But i did check your stats. Although, ~20% of your post were liked only 5% were solutions. So i guess mentor status is not based on solutions. Have a nice day! Stay safe!
Boris
Message 82 of 102
Stop jamming up my email. Both of you need to go for a walk. I still
haven't solved my issue with the autocad update or any other suggestions
from this reel nor any autocad support. And this bickering isn't helping
anyones sanity.
Message 83 of 102
btillett
I apologize for indulging in that divergence. I looked at your original post and just wanted to let you know that when i was discussing this with Autodesk they said they had a hotfix for 2020, but it was only given out on request. So it is important that you open a help ticket with them, they may have the answer.
I do apologize for all the emails that everyone on this thread must have received, from the ridiculous unrelated conversation above.
Boris
Message 84 of 102
RobDraw
This thread has been solved multiple times. Maybe you should start your own.
Rob
Message 85 of 102
cadffm
Hi @Anonymous
i am waiting for your feedback since 3 month..
Screenshot of Command: ABOUT dialog
and a sample DWG (simple as possible to show the problem)
You never shared productversion and details of your problem.
Sebastian
Message 86 of 102
My company does not allow me to share our work documents and as all of our
have xref links from other companies. I'm not sure as how I can send you a
legitimate copy of the issue I'm having.
Message 87 of 102
RobDraw
It took three months for you to come back with that?! Maybe you shouldn't start a new thread. The issue needs to be replicated in order for you to get a possible solution.
Rob
Message 88 of 102
RobDraw
@btillett wrote:
i am done.
But yet you continue.
Still trying to make something personal out of this? Did you think that I didn't know that the title was based on post count? I can think of a couple good titles for you that have nothing to with post count.
Rob
Message 89 of 102
tomlynham6453
May 2021 and that hotfix link is now broken.  What a ****show.
Message 90 of 102
cadffm
Grumble less, read and understand more. 😖
The link is broken because it is no longer needed.
https://forums.autodesk.com/t5/autocad-forum/draw-order-in-2019-not-working/m-p/8289439#M950379
Sebastian
Message 91 of 102
pendean
Community Legend
Community Legend
@tomlynham6453 Which hotfix is that and where for you is the broken link?
Message 92 of 102
tomlynham6453
This entire thread is a litany of you getting into little spats with people.  You might consider a career change.
Message 93 of 102
RobDraw
How does one correlate with the other?
Rob
Message 94 of 102
tomlynham6453
Wow, I guess calling Autodesk's unnavigable mess of patches and hotfixes a ****show is like putting out a hot steaming bowl of Troll bait.  You guys need to chill out.
Message 95 of 102
pendean
Community Legend
Community Legend
@tomlynham6453 All of us can get all the software updates here https://manage.autodesk.com/cep/#products-services/updates
There is no secret link needed.
If it's working and you have it installed, you can also get updates from the installed Autodesk Desktop App that installs by default with AutoCAD2019 (in your case).
It would appear you are seeking the 2019.1.2 update. Remember to restart your computer after installation, don't skip that step.
HTH
Message 96 of 102
RobDraw
When your opinion is based on fiction, you should expect some opposition.
Rob
Message 97 of 102
tomlynham6453
Oh boy, how many times have you used that one in your little nerd fights.  Here's one:
"When you show up uninvited as the 'opposition' to someone an Autodesk forum, YTA"
Message 98 of 102
cadffm
Just for me ( please come back on topic )
The hotfix only makes sense if you do have installed 2019.0.1 and you not want to install either the 2019.1.2 or 2019.1.1 update,
but why would you want to continue to use 2019.0.1 , no 2019.1.0, no 2019.1.1 or the current version 2019.1.2?
Sebastian
Message 99 of 102
tomlynham6453
Yes, thank you.  (And thank you to Pendean for genuinely attempting to help)
I already have the 2019.1.2 hotfix applied.  I wanted to try the earlier patch since the 2019.1.2 did not solve the draworder issue.  Based on the comments in the thread that were actually helpful, this seemed to have solved the problem for at least one user.  (Thank you for the link to the zip file that just came through as well.)
Take a toxic forum, throw in a now-broken link (regardless of the relatively easy availability of a more recent patch) and I call that a ****show.
My next step is an upgrade to 2022, so none of this will matter.  Thanks anyway.
Message 100 of 102
cadffm
2019.1.2 includes this hotfix,
you are fighting with another problem.
Perhaps a Draworder bug, but not the bug which is solved by this hotfix.
You should start your own thread and share a sample dwg, screenshots,screencasts,explainations.
Perhaps you handle with images and your hardware acceleration is turned off,
Or you are talking about objects in Layout and your pagesetup is wrong.
Nobody on our side  can say it is a bug, without to know the details of your issue.
Sebastian
