Draw a line from its midpoint
Message 1 of 15
Hi, this is kind of hard to explain, but is there a way to draw a line starting at its midpoint? Like if I want to draw a 10 inch line i pick a point and it extends out in both directions 5 inches. Kind of like how you draw a circle. Sorry if this is a stupid question, or if it is super simple or easy to do.
Thanks for taking the time to read this, and any help is greatly appreciated.
Replies (14)
Message 2 of 15
Alfred.NESWADBA
you might use a block as replacement for a line. The block can contain a line from -1,0 to +1,0 ... when you then insert the block you can show rotation and scalefactor and the result would be a (visual) line which has it's midpoint where you showed the insertion point of the block.
I would not know a function that can do that in AutoCAD.
Alterative could be to use commands _LENGTHEN or _SCALE, but then the line has already to exist.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 15
dbroad
Use an xline and trim.
Architect, Registered NC, VA, SC, & GA.
Message 4 of 15
john.vellek
Hi @Anonymous,
There is no in-the-box way to do this.  You could construct a dynamic block that inserts at the middle and then allows you to stretch the line. Or, perhaps a visit to the customization forum will get you a lisp routine that does this for you.
John Vellek
Message 5 of 15
Kent1Cooper
If you don't mind not seeing both ends stretch, but you're open to drawing half of it and then having it "finished" to full length [in simplest terms]:
(defun C:LineMid ()
  (command
    "_.LINE" pause pause ""
    "_.scale" "_last" "" "@" 2
  ); command
  (princ)
Prompts could be added where those pauses are, to make it clear what you're going to get.
To see it "drag" at both ends as you draw it, a routine using (grread) and (grdraw) shouldn't be hard to work out.
Kent Cooper, AIA
Message 6 of 15
Kent1Cooper
Such as this quickie:
;;  LineMidPoint.lsp [command name: LMP]
;;  To draw a Line starting from its midpoint, rather than from end
;;    to end as in AutoCAD's LINE command.
;;  Drags shape of resulting Line as cursor is moved.
;;  Kent Cooper, 4 January 2019
(defun C:LMP ; = Line from MidPoint
  (/ mid cur cor1 cor3 delta bulge cor2 cor4 prelist vertices rect)
  (setq mid (getpoint "\nMidpoint of Line: "))
  (prompt "\nOne end of Line: ")
  (while
    (and mid (setq cur (grread T 12 0)))
    (cond
      ((= (car cur) 5); moved cursor - draw vector
        (grdraw
          (cadr cur)
          (polar mid (angle (cadr cur) mid) (distance (cadr cur) mid))
          -1 1 ; contrast color to background, highlight
        ); grdraw
      ); moved-cursor condition
      ((= (car cur) 3); picked point - draw Line, end (while) loop
        (entmake
          (list
            '(0 . "LINE")
            (cons 10 (cadr cur))
            (cons 11 (polar mid (angle (cadr cur) mid) (distance (cadr cur) mid)))
          ); list
        ); entmake
        (setq mid nil); end (while) loop
      ); picked-point condition
    ); cond - grread possibilities
  ); while
  (princ)
); defun - LMP
(prompt "\nType LMP to draw a Line starting at its MidPoint.")
Unfortunately, it doesn't honor Osnap for picking the one endpoint [though it does for the midpoint].
Kent Cooper, AIA
Message 7 of 15
CRGDesign
Community Visitor
Community Visitor
Another very basic tool every other CAD software has that AUTOCAD doesnt...
Message 8 of 15
ryanYF2FK
I was getting graphical glitches when I tried Kent Cooper's. It may be an issue of what versions we're using.
Anyway, I made up my own. Activate with "LMID".
Update: I started getting odd errors, and found that there are several situations that break what I made. I'm pulling this down until I can figure out the issue.
Message 9 of 15
Kent1Cooper
@ryanYF2FK wrote:
I was getting graphical glitches when I tried Kent Cooper's. ....
[Which one?  What kinds of issues?]
Kent Cooper, AIA
Message 10 of 15
ryanYF2FK
With LMP, I was getting ghosted images like in this photo.
The first one you shared (LineMid) seems to work great! I completely missed it when I was reading through the comments originally. Now if I fix mine, it'll only be for the practice haha
Message 11 of 15
pendean
Community Legend
Community Legend
I bet a REGEN or REGENALL command fixes that, doesn't it.
Your video card choked, nothing more: share with us screenshots of your AutoCAD's ABOUT and GRAPHICSCONFIG command pop-ups please.
Message 12 of 15
ryanYF2FK
I tried both regeneration commands and it didn't fix it. But I still admit it's probably my graphic's card - it's on my work computer, and I've had problems with it ever since they bought it.
Should I make this into a separate post somewhere? Not trying to spam everyone.
Message 13 of 15
cadffm
regardless of the problem here:
You have installed "less important" updates for Architecture, but not a single update for AutoCAD?
AutoCAD Productversion, current is 2025.1.1
[F1] https://help.autodesk.com/view/ARCHDESK/2025/ENU/?guid=AUTOCAD_2025_UPDATES
Sebastian
Message 14 of 15
ryanYF2FK
Good catch, thanks. I've got that fixed now.
Message 15 of 15
vladimir_michl
A useful tool. Extended now with osnaps (LeeMac's), center glyph and fixed-distance option:
;;  Osnaps, Dist, Center glyph - V.Michl, www.cadforum.cz, 4/2026
  (/ mid cur cor1 cor3 delta bulge cor2 cor4 prelist vertices rect osf ospt vs mode distf)
;; Object Snap for grread: Snap Function  -  Lee Mac
;; Returns: [fun] A function requiring two arguments:
;; p - [lst] UCS Point to be snapped
;; o - [int] Object Snap bit code
;; The returned function returns either the snapped point (displaying an appropriate snap symbol)
;; or the supplied point if the snap failed for the given Object Snap bit code.
(defun LM:grsnap:snapfunction ( )
    (eval
        (list 'lambda '( p o / q )
            (list 'if '(zerop (logand 16384 o))
                (list 'if
                   '(setq q
                        (cdar
                            (vl-sort
                                (vl-remove-if 'null
                                    (mapcar
                                        (function
                                            (lambda ( a / b )
                                                (if (and (= (car a) (logand (car a) o)) (setq b (osnap p (cdr a))))
                                                    (list (distance p b) b (car a))
                                            (0001 . "_end")
                                            (0002 . "_mid")
                                            (0004 . "_cen")
                                            (0008 . "_nod")
                                            (0016 . "_qua")
                                            (0032 . "_int")
                                            (0064 . "_ins")
                                            (0128 . "_per")
                                            (0256 . "_tan")
                                            (0512 . "_nea")
                                            (2048 . "_app")
                                            (8192 . "_par")
                               '(lambda ( a b ) (< (car a) (car b)))
                    (list 'LM:grsnap:displaysnap '(car q)
                        (list 'cdr
                            (list 'assoc '(cadr q)
                                (list 'quote
                                    (LM:grsnap:snapsymbols
                                        (atoi (cond ((getenv "AutoSnapSize")) ("5")))
                        (LM:OLE->ACI
                            (if (= 1 (getvar 'cvport))
                                (atoi (cond ((getenv "Layout AutoSnap Color")) ("117761")))
                                (atoi (cond ((getenv  "Model AutoSnap Color")) ("104193")))
           '(cond ((car q)) (p))
;; Object Snap for grread: Display Snap  -  Lee Mac
;; pnt - [lst] UCS point at which to display the symbol
;; lst - [lst] grvecs vector list
;; col - [int] ACI colour for displayed symbol
;; Returns nil
(defun LM:grsnap:displaysnap ( pnt lst col / scl )
    (setq scl (/ (getvar 'viewsize) (cadr (getvar 'screensize)))
          pnt (trans pnt 1 2)
    (grvecs (cons col lst)
        (list
            (list scl 0.0 0.0 (car  pnt))
            (list 0.0 scl 0.0 (cadr pnt))
            (list 0.0 0.0 scl 0.0)
           '(0.0 0.0 0.0 1.0)
;; Object Snap for grread: Snap Symbols  -  Lee Mac
;; p - [int] Size of snap symbol in pixels
;; Returns: [lst] List of vector lists describing each Object Snap symbol
(defun LM:grsnap:snapsymbols ( p / -p -q -r a c i l q r )
    (setq -p (- p) q (1+  p)
          -q (- q) r (+ 2 p)
          -r (- r) i (/ pi 6.0)
           a 0.0
    (repeat 12
        (setq l (cons (list (* r (cos a)) (* r (sin a))) l)
              a (- a i)
    (setq c (apply 'append (mapcar 'list (cons (last l) l) l)))
    (list
        (list 1
            (list -p -p) (list p -p) (list p -p) (list p p) (list p p) (list -p p) (list -p p) (list -p -p)
            (list -q -q) (list q -q) (list q -q) (list q q) (list q q) (list -q q) (list -q q) (list -q -q)
        (list 2
            (list -r -q) (list 0  r) (list 0  r) (list r -q)
            (list -p -p) (list p -p) (list p -p) (list 0  p) (list 0  p) (list -p -p)
            (list -q -q) (list q -q) (list q -q) (list 0  q) (list 0  q) (list -q -q)
        (cons 4 c)
        (vl-list* 8 (list -r -r) (list r r) (list r -r) (list -r r) c)
        (list 16
            (list p 0) (list 0 p) (list 0 p) (list -p 0) (list -p 0) (list 0 -p) (list 0 -p) (list p 0)
            (list q 0) (list 0 q) (list 0 q) (list -q 0) (list -q 0) (list 0 -q) (list 0 -q) (list q 0)
            (list r 0) (list 0 r) (list 0 r) (list -r 0) (list -r 0) (list 0 -r) (list 0 -r) (list r 0)
        (list 32
            (list  r r) (list -r -r) (list  r q) (list -q -r) (list  q r) (list -r -q)
            (list -r r) (list  r -r) (list -q r) (list  r -q) (list -r q) (list  q -r)
        (list 64
            '( 0  1) (list  0  p) (list  0  p) (list -p  p) (list -p  p) (list -p -1) (list -p -1) '( 0 -1)
            '( 0 -1) (list  0 -p) (list  0 -p) (list  p -p) (list  p -p) (list  p  1) (list  p  1) '( 0  1)
            '( 1  2) (list  1  q) (list  1  q) (list -q  q) (list -q  q) (list -q -2) (list -q -2) '(-1 -2)
            '(-1 -2) (list -1 -q) (list -1 -q) (list  q -q) (list  q -q) (list  q  2) (list  q  2) '( 1  2)
        (list 128
            (list (1+ -p) 0) '(0 0) '(0 0) (list 0 (1+ -p))
            (list (1+ -p) 1) '(1 1) '(1 1) (list 1 (1+ -p))
            (list -p q) (list -p -p) (list -p -p) (list q -p)
            (list -q q) (list -q -q) (list -q -q) (list q -q)
        (vl-list* 256 (list -r r)  (list r r) (list -r (1+ r)) (list r (1+ r)) c)
        (list 512
            (list -p -p) (list  p -p) (list -p  p) (list p p) (list -q -q) (list  q -q)
            (list  q -q) (list -q  q) (list -q  q) (list q q) (list  q  q) (list -q -q)
        (list 2048
            (list   -p     -p) (list    p      p) (list   -p      p) (list    p     -p)
            (list (+ p 05) -p) (list (+ p 06) -p) (list (+ p 05) -q) (list (+ p 06) -q)
            (list (+ p 09) -p) (list (+ p 10) -p) (list (+ p 09) -q) (list (+ p 10) -q)
            (list (+ p 13) -p) (list (+ p 14) -p) (list (+ p 13) -q) (list (+ p 14) -q)
        (list 8192 (list r 1) (list -r -q) (list r 0) (list -r -r) (list r q) (list -r -1) (list r r) (list -r 0))
;; Object Snap for grread: Parse Point  -  Lee Mac
;; bpt - [lst] Basepoint for relative point input, e.g. @5,5
;; str - [str] String representing point input
;; Returns: [lst] Point represented by the given string, else nil
(defun LM:grsnap:parsepoint ( bpt str / str->lst lst )
    (defun str->lst ( str / pos )
        (if (setq pos (vl-string-position 44 str))
            (cons (substr str 1 pos) (str->lst (substr str (+ pos 2))))
            (list str)
    (if (wcmatch str "`@*")
        (setq str (substr str 2))
        (setq bpt '(0.0 0.0 0.0))
    (if
        (and
            (setq lst (mapcar 'distof (str->lst str)))
            (vl-every 'numberp lst)
            (< 1 (length lst) 4)
        (mapcar '+ bpt lst)
;; Object Snap for grread: Snap Mode  -  Lee Mac
;; str - [str] Object Snap modifier
;; Returns: [int] Object Snap bit code for the given modifier, else nil
(defun LM:grsnap:snapmode ( str )
    (vl-some
        (function
            (lambda ( x )
                (if (wcmatch (car x) (strcat (strcase str t) "*"))
                    (progn
                        (princ (cadr x)) (caddr x)
            ("endpoint"      " of " 00001)
            ("midpoint"      " of " 00002)
            ("center"        " of " 00004)
            ("node"          " of " 00008)
            ("quadrant"      " of " 00016)
            ("intersection"  " of " 00032)
            ("insert"        " of " 00064)
            ("perpendicular" " to " 00128)
            ("tangent"       " to " 00256)
            ("nearest"       " to " 00512)
            ("appint"        " of " 02048)
            ("parallel"      " to " 08192)
            ("none"          ""     16384)
;; OLE -> ACI  -  Lee Mac
;; Args: c - [int] OLE Colour
(defun LM:OLE->ACI ( c )
    (apply 'LM:RGB->ACI (LM:OLE->RGB c))
;; OLE -> RGB  -  Lee Mac
(defun LM:OLE->RGB ( c )
    (mapcar '(lambda ( x ) (lsh (lsh (fix c) x) -24)) '(24 16 8))
;; RGB -> ACI  -  Lee Mac
;; Args: r,g,b - [int] Red, Green, Blue values
(defun LM:RGB->ACI ( r g b / c o )
    (if (setq o (vla-getinterfaceobject (LM:acapp) (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2))))
        (progn
            (setq c (vl-catch-all-apply '(lambda ( ) (vla-setrgb o r g b) (vla-get-colorindex o))))
            (vlax-release-object o)
            (if (vl-catch-all-error-p c)
                (prompt (strcat "\nError: " (vl-catch-all-error-message c)))
                c
;; Application Object  -  Lee Mac
;; Returns the VLA Application Object
(defun LM:acapp nil
    (eval (list 'defun 'LM:acapp 'nil (vlax-get-acad-object)))
    (LM:acapp)
  (prompt "\nOne end of Line [Distance/Float]: ")
  (setq osf (LM:grsnap:snapfunction)) ; osnap
  (setq mode "F")
  (while
    (and mid (setq cur (grread T 12 0))) ; was 12, 13?
    (setq vs (/ (getvar "VIEWSIZE") 100.0))
    (redraw)
  (grvecs (list 1
				(polar mid 0 vs) (polar mid 1.57 vs)
				(polar mid 1.57 vs) (polar mid 3.14 vs)
				(polar mid 3.14 vs) (polar mid 4.71 vs)
				(polar mid 4.71 vs) (polar mid 6.28 vs)
    (cond
	   (if (= mode "F")
	    (setq ospt (osf (cadr cur) (getvar "OSMODE")))
	    (setq ospt (polar mid (angle (cadr cur) mid) distf))
        (grdraw
          ospt ; (cadr cur)
		 (if (= mode "F")
           (polar mid (angle ospt mid) (distance ospt mid))
		  (polar mid (angle mid (cadr cur)) distf)
          -1 1 ; contrast color to background, highlight 1
        ); grdraw
	   (if (= mode "F")
        (entmake
          (list
            '(0 . "LINE")
            (cons 10 ospt)
	       (if (= mode "F")
             (cons 11 (polar mid (angle ospt mid) (distance ospt mid)))
             (cons 11 (polar mid (angle mid (cadr cur)) distf))
          ); list
        ); entmake
	  ((= (car cur) 2)
	    (if (member (chr (cadr cur)) '("d" "D")) (progn (setq mode "D") (setq distf (getdist " Fixed distance: "))))
	    (if (member (chr (cadr cur)) '("f" "F")) (setq mode "F"))
	  ;(T (princ cur)) ; else
  ); while
  (redraw)
  (princ)
); defun - LMP
(prompt "\nType LMP to draw a Line starting at its MidPoint. ")
Vladimir Michl, www.arkance.world - www.cadforum.cz
