Draw a line from its midpoint
Message 1 of 14
Hi, this is kind of hard to explain, but is there a way to draw a line starting at its midpoint? Like if I want to draw a 10 inch line i pick a point and it extends out in both directions 5 inches. Kind of like how you draw a circle. Sorry if this is a stupid question, or if it is super simple or easy to do.
Thanks for taking the time to read this, and any help is greatly appreciated.
Replies (13)
Message 2 of 14
Alfred.NESWADBA
you might use a block as replacement for a line. The block can contain a line from -1,0 to +1,0 ... when you then insert the block you can show rotation and scalefactor and the result would be a (visual) line which has it's midpoint where you showed the insertion point of the block.
I would not know a function that can do that in AutoCAD.
Alterative could be to use commands _LENGTHEN or _SCALE, but then the line has already to exist.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 14
dbroad
Use an xline and trim.
Architect, Registered NC, VA, SC, & GA.
Message 4 of 14
john.vellek
Hi @Anonymous,
There is no in-the-box way to do this.  You could construct a dynamic block that inserts at the middle and then allows you to stretch the line. Or, perhaps a visit to the customization forum will get you a lisp routine that does this for you.
John Vellek
Message 5 of 14
Kent1Cooper
If you don't mind not seeing both ends stretch, but you're open to drawing half of it and then having it "finished" to full length [in simplest terms]:
(defun C:LineMid ()
  (command
    "_.LINE" pause pause ""
    "_.scale" "_last" "" "@" 2
  ); command
  (princ)
Prompts could be added where those pauses are, to make it clear what you're going to get.
To see it "drag" at both ends as you draw it, a routine using (grread) and (grdraw) shouldn't be hard to work out.
Kent Cooper, AIA
Message 6 of 14
Kent1Cooper
Such as this quickie:
;;  LineMidPoint.lsp [command name: LMP]
;;  To draw a Line starting from its midpoint, rather than from end
;;    to end as in AutoCAD's LINE command.
;;  Drags shape of resulting Line as cursor is moved.
;;  Kent Cooper, 4 January 2019
(defun C:LMP ; = Line from MidPoint
  (/ mid cur cor1 cor3 delta bulge cor2 cor4 prelist vertices rect)
  (setq mid (getpoint "\nMidpoint of Line: "))
  (prompt "\nOne end of Line: ")
  (while
    (and mid (setq cur (grread T 12 0)))
    (cond
      ((= (car cur) 5); moved cursor - draw vector
        (grdraw
          (cadr cur)
          (polar mid (angle (cadr cur) mid) (distance (cadr cur) mid))
          -1 1 ; contrast color to background, highlight
        ); grdraw
      ); moved-cursor condition
      ((= (car cur) 3); picked point - draw Line, end (while) loop
        (entmake
          (list
            '(0 . "LINE")
            (cons 10 (cadr cur))
            (cons 11 (polar mid (angle (cadr cur) mid) (distance (cadr cur) mid)))
          ); list
        ); entmake
        (setq mid nil); end (while) loop
      ); picked-point condition
    ); cond - grread possibilities
  ); while
  (princ)
); defun - LMP
(prompt "\nType LMP to draw a Line starting at its MidPoint.")
Unfortunately, it doesn't honor Osnap for picking the one endpoint [though it does for the midpoint].
Kent Cooper, AIA
Message 7 of 14
CRGDesign
Community Visitor
Community Visitor
Another very basic tool every other CAD software has that AUTOCAD doesnt...
Message 8 of 14
ryanYF2FK
I was getting graphical glitches when I tried Kent Cooper's. It may be an issue of what versions we're using.
Anyway, I made up my own. Activate with "LMID".
Update: I started getting odd errors, and found that there are several situations that break what I made. I'm pulling this down until I can figure out the issue.
Message 9 of 14
Kent1Cooper
@ryanYF2FK wrote:
I was getting graphical glitches when I tried Kent Cooper's. ....
[Which one?  What kinds of issues?]
Kent Cooper, AIA
Message 10 of 14
ryanYF2FK
With LMP, I was getting ghosted images like in this photo.
The first one you shared (LineMid) seems to work great! I completely missed it when I was reading through the comments originally. Now if I fix mine, it'll only be for the practice haha
Message 11 of 14
pendean
Community Legend
Community Legend
I bet a REGEN or REGENALL command fixes that, doesn't it.
Your video card choked, nothing more: share with us screenshots of your AutoCAD's ABOUT and GRAPHICSCONFIG command pop-ups please.
Message 12 of 14
ryanYF2FK
I tried both regeneration commands and it didn't fix it. But I still admit it's probably my graphic's card - it's on my work computer, and I've had problems with it ever since they bought it.
Should I make this into a separate post somewhere? Not trying to spam everyone.
Message 13 of 14
cadffm
regardless of the problem here:
You have installed "less important" updates for Architecture, but not a single update for AutoCAD?
AutoCAD Productversion, current is 2025.1.1
[F1] https://help.autodesk.com/view/ARCHDESK/2025/ENU/?guid=AUTOCAD_2025_UPDATES
Sebastian
Message 14 of 14
ryanYF2FK
Good catch, thanks. I've got that fixed now.
