Drafting Help
Drafting Help
apanbasu
Message 1 of 10
Drafting Help
apanbasu
I am using Auto Cad 2019 version.
I just came to a problem and the solution is beyond me. I have attached a drawing showing the location in clouded area. I could not Fillet, could not extend, could not offset. When I try to offset 24" - it offsets 12" and also in a different spot not parallel.
Where I messed myself up.
Please help.
Accepted solutions (3)
Replies (9)
Message 2 of 10
paullimapa
Enter the following commands:
VSCURRENT 2DWIREFRAME
PLAN WORLD
Paul Li
IT Specialist
@The Office
Message 3 of 10
pendean
Community Legend
Community Legend
@apanbasu Are you trying to edit your XREF from the top file (without entering the xrefs)?
PLUS what @paullimapa wrote too (see attached)
Message 4 of 10
apanbasu
It solved the offset and extension command but will not work for fillet command. I am experiencing this problem on this drawing only. There is no issue on other drawings
I was able to show the offset using trim and extension. But I prefer to have rounded corners.
Still it helped and thank you for the help.
Message 5 of 10
apanbasu
I was not trying to change any drawing on xref. The drawing you have attached without xref is my working drawing. As I said to my reply to Mr. Li - the offset and extension is working but not fillet with the command he suggested.
I modified drawings with extension but I prefer to have rounded corners.
Message 6 of 10
paullimapa
First use the FLATTEN command by selecting the objects that are non coplanar (LINES you want to FILLET)
Then you can run the FILLET command on them.
Also I tend to leave LWDISPLAY set to OFF so the display doesn't get all cluttered up.
Paul Li
IT Specialist
@The Office
Message 7 of 10
pendean
Community Legend
Community Legend
@apanbasu wrote:
...but will not work for fillet command....
I bet there was an error message at the commandline, wasn't there. Look again. Then look at your drawing, which is this
FLATTEN command is what the error message you got from FILLET command was needing you to do. HTH
Message 8 of 10
apanbasu
Thank you. Thank you. It worked. I am 89 years old. Just stay there to help
me a few more years.
Sincerely,
Apan Basu, PE
5216 Pelham Road
Durham, NC 27713
(P) 919-484-2111
Message 9 of 10
apanbasu
I did not see any message in the command line. But i will expand the command line to see for the error message
But I uses LWDISPLAY set to OFF as suggested by Mr. Li and it worked.
I thank you all for extending helping hand to this old man.
Message 10 of 10
paullimapa
you are welcome...just keep at it...we're all still learning more each and every day...cheers!!!
Paul Li
IT Specialist
@The Office
