I am not able to find autocad 2014 free trial setup file
@Anonymous, john.vellek has edited your subject line for clarity:Free trial
Solved by markcalloway. Go to Solution.
Please use the Autodesk virtual agent to download AutoCAD 2014, during the setup just select the 30 free trial:
Hi amithprasad96,
Welcome to the Community.
Did @markcalloway's excellent solution help you to obtain the trial version you are looking for? Be aware also, (depending on your workstation and operating system) that you can also download the most current version and it will open and save to 2013 file versions.
Please let me know if you have additional questions or concerns regarding this issue.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
Hi @Anonymous,
I am checking back to see if a post helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post fully solves your issue or answers your question.
