- Mute
- Permalink
- Report
Hi
I have a problem with a autocad architecture 2016 file that I haven't been able to find a solution on. A single line will be represented as two or even as a pipe two when I print them to pdf. I usually print from layout space without any special settings and then import the pdf to illustrator where I fine-tune the drawing.
I found this post with a seeming similar problem:https://forums.autodesk.com/t5/autocad-forum/polyline-global-width-is-displayed-as-two-lines-instead...
I tried all the suggested solutions without any luck. When I did the "UCS, W. and PLAN, W." it did however change where the problem occured in my drawing. So I think the problem might be related to the ucs somehow, but I can't manage to fix it.
Enclosed are the autocad drawing along with a pdf taken through illustrator. You will see the problem for example on the small staircase in the upper left corner of the drawing.
I greatly appreciate any help. I've used this forum many times but this is the first time I've had to make a post of my own.
