Double click on block doesn't open attribute editor
Message 1 of 8
I have AutoCAD 2018 installed.  When I double click on a block to edit the attributes, the Enhanced Block Editor doesn't open, it only opens the Properties palette?  I have to keyin DDEDIT and select the block to edit the attributes.  Never seen this before.  There must be a setting that controls this?  Any help would be appreciated.  Thanks!
Replies (7)
Message 2 of 8
Sorry, I'm using google translate
The reason is just that the block has an attribute.
Try removing it and you'll see that you open the block editor.
Júnior Nogueira.
Por favor,  Aceitar como Solução se meu post te ajudar.
Please Accept as Solution if my post helps you.
Message 3 of 8
user181
Hi @Anonymous, a couple things to check. Make sure PICKFIRST is set to 1 and DBLCLKEDIT is set to ON
Message 4 of 8
jayhar
Enter new value for BLOCKEDITLOCK <0>
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 5 of 8
I'm having the same problem with 2015 and non of the solutions worked
Message 6 of 8
RobDraw
Start a new thread. This one has a solution.
Rob
Message 7 of 8
cadffm
Then you have another issue, with the same symtom.
AND Attach a DWG with one of these block reference!
Then we can see what the problem is - (the Click goes to another object than an attribut, perhaps an attdef/constant)
Sebastian
Message 8 of 8
martin9KN26
I had the same issue/symptom.
In my case the cause was an attribute that was in an invisible Visibility State.
